11-19-2012, 09:56 PM
#21
Originally Posted by andrew78
i'm so excited!!
i hit the jackpot today, not the lotto but pretty closes. I found a frame!!!
I love it when a plan comes together
Post pictures and let us know about challenges that you run into. Others may benefit by your experiences.
11-19-2012, 10:24 PM
#22
Trailer: 1985 U-Haul CT-13
i'm so excited!!
it is off a rockwood freedom pop up trailer that had the roof crushed by a tree.
frame is very close, will need some minor cuts put nothing major. the length is perfect and the axle is in the exact same spot. and the bonus is it has brakes. stripped the whole trailer in about three hours. lots of extra goodies.
i can't wait to get uhaul off the ground,
Very Excellent!!!
Hope your fastener points line up for you without too much extra fabrication but it will sure beat starting from scratch.
11-19-2012, 10:31 PM
#23
Trailer: Bigfoot 17 ft (15B17G)
Giddy up
Well done, looking forward to hearing how this plays out!
11-19-2012, 10:47 PM
#24
Trailer: U-Haul 1985
How great for you that a new frame fell into your lap! (metaphorically speaking, of course !!) Keep the pics of this project coming!
11-19-2012, 11:32 PM
#25
Trailer: '78 Trillium 4500
Glad to hear that you found a frame- hope the "minor cuts" don't amount to much!
12-01-2012, 08:33 AM
#26
Trailer: 17 boler
I brought home my new frame tonight, tows perfectly. (pictures to be posted shortly)
the uhaul were mount to the frames with bolts. between the frame and the body are anti vibration disc. THe new fram needs long strips as i'm going to do the whole frame. does anybody has any suggestions on what to use? it would need to be about 1" Wide. i was thinking something that came in a roll, I could glue on, but could also by something and cut it in strips.
asking the experts for help, thats you guys
thanks
12-01-2012, 09:01 AM
#27
thanks
Andrew, are you asking what to use in place of the rubber washers? One place to get rubber sheet fairly cheaply is to buy heavy truck mud flaps. They sell them at automotive stores and truck stop supply places.
Another option is off the internet, like these places:
Sheet Rubber Prices, Availability - Updated Daily
http://www.zorotools.com/g/Rubber%20...hick/00093259/
12-01-2012, 12:09 PM
#28
Trailer: 17 boler
sorry i forgot t omention what i was replacing, yes i'm replacing the rubber disc. i never thought of mud flaps. i will check those websites as well
thanks for ideas
12-01-2012, 12:12 PM
#29
I use rubber belting for applications like this.
I've got some that was thrown away at the local mill...if one's in farm country, farmers go through quite a bit of it, too. One can also buy small quantities online. Most is wider than an inch, but can of course be cut with a utility knife
6" 3 Ply Thresher, Conveyor, Baler Belting ~ Priced Per Foot
Francesca
12-01-2012, 12:19 PM
#30
Trailer: 1984 19' scamp
Kansas
Baler belt was going to be my suggestion. It will outlast mudflaps, even used belting will, IMHO.
12-01-2012, 12:42 PM
#31
Thank goodness for farmers.
I agree this rubberized belting would also work. All you need to do is to spread the load slightly in the vicinity of the body to frame bolt.
12-01-2012, 06:29 PM
#32
Trailer: Cardinal (Restoring)
Welcome to the site Andrew. It is so exciting for us all to watch a project in progress. As was said previously, any thing you need help with or answers too, you will find here. Some of the most knowledgable people I have ever encountered. Dont get discouraged, you will have an amazing RV when you are finished. Just take it slow and easy. Keep the photos coming and good luck from California, USA
03-07-2013, 09:04 AM
#33
Trailer: 17 boler
so its been a while since i have done anything on my trailer. my wife would rather have her car in our garage over the winter than the trailer.
I have finished the frame, and about to attach the shell to the frame. just wanted to know what people thought is the best way to attach the two together?
the frame is not all a round tube frame, some of it is a square frame and u-channel.
i was thinking just using metal screws instead of bolts, any thoughts or comments are always welcome on what i should do
thanks
andrew
i promise to post more pictures tonight
03-07-2013, 10:13 AM
#34
I replaced the Fiber Stream 5/16" carriage bolts with stainless steel elevator bolts, lock washers, and nuts. This worked very well for me. Elevator bolts are essentially carriage bolts with a large, flat, 1" diameter head.
Vic
03-07-2013, 10:20 AM
#35
Vic
+1 on elevator bolts.
https://www.google.com/search?hl=en&...GuTYyAGXgYGQCA
03-07-2013, 10:24 AM
#36
Trailer: 1979 Trillium 4500
Trillium bodies are bolted through the frame with a large washer on the inside of the body and a washer, lock washer and nut on the outside. I would think that a bolt would be more secure, less likely to come loose, and better able to be cinched tight than a screw. my 2 cents worth.
Reid
03-07-2013, 10:46 AM
#37
Trailer: 17 boler
i was thinking bolts but when i took apart a popup trailer for the frame it was just screwed together.
bolts it is then
03-07-2013, 11:27 AM
#38
I had the bolts on my trailer installed with the nut on the inside. That way rust would be less of a problem. It almost made putting the porta-potty in it's garage impossible. I had to cut the bolt off flush with the nut.
03-07-2013, 11:34 AM
#39
when I replaced the rusted away original elevator bolts in the floor of our Uhaul I used 5/16 bolts instead of the original 1/4" size. And instead of elevator bolts I used a grade 5 bolt with a large fender washer against the floor, flat washer and lock washer against the frame.
03-07-2013, 01:41 PM
#40
Trailer: 1978 Trillium 4500
Use bolts. At some point someone will want to unscrew things again.
I used stainless steel bolts, but I ran into problems with metal seizing. See:
http://www.fiberglassrv.com/forums/f...-up-51193.html
Switched to galvanized. Due to cost and availability issues, I ended up using regular hex bolt heads and a large fender washer.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
