Attached is the milage log that for tire I have used for my 2011 SD 16-ft
Scamp.
Best placed I have found to get tires is Discount Tires. Make sure that you have them balanced before installing them on the Scamp. Also good time to have wheel nearing repacked.
Henry
Scamp 2011 Maintenance / Tire Log Scamp 16-ft SD FB
SIZE Load Range Weight LoadTotal Mileage
12/11/10 Tires Tow Master (Scamp OEM) ST 195 / 13 LR C 15,172.0 miles
10/05/11 Tires Hi Run (Up Grade Tires w/ 5 Lug 14-in Rim ST 205 / 75 R 14 C 9,087.0 miles
10/08/12 Tires Master Track (Eureka MO) ST 205 / 75 R 14 C 1,760 29,284.0 miles
06/23/14 Maint - Wheel Bearing Replace /Repack 49,913.0
10/16/14 Tires Goodyear Marthon ST 205 / 75 R 14 C 1,760.0 1500 miles todate
