1983 16' Casita Repair/Rebuild - Page 2 - Fiberglass RV
Old 02-25-2020, 10:25 PM   #21
Trailer: Casita 16ft.
Originally Posted by zgrammon View Post
So I started on the bunk bulkheads today. I'm scratching my head a bit over just how much to pull the sagging shell up to snuff.
Here are a few snapshots of one of the bulkheads against the shell. The bulkhead was cut from the profile of the piece of shower stall fiberglass.
Attachment 133357
Attachment 133358
Here's what I found when I did this same job on my trailer. I doubt that you will find two places that are the same profile in the fore to aft direction. Side to opposite side they will be pretty close. As to finding the right amount of height, I found that jacking up or letting it down until: 1) the door strike lined up and worked smoothly. 2) when sighting down the outside of the trailer and it looked straight ( it's a subjective call) then it's good'nuff. If you jack up it too much, you will see an indention along the belly band telling you to let the jack down a bit. Bear in mind that a sagging trailer will continue to pull back in shape over time. so what it looks like on day one, it may change a little by day twelve. It took my fender boxes which were leaning out a couple of weeks to pull back in line after the roof was supported.
Nor Cal Mike is offline   Reply With Quote
Old 02-25-2020, 11:06 PM   #22
@Mike Good point about the varying profile. In the photo, these are the same spot, side to opposite side.
I think I'll try jacking the ceiling of the shell up for a time and see how things shift. From what you are saying, the pooching out right around the belly band might indicate that the height needs to be another inch or so up from where things stand right now.
zgrammon is offline   Reply With Quote
Old 02-26-2020, 07:35 AM   #23
Missouri
mike i just have to ask
mike are you a paint and body man?
you are waaaay too good at this? LOL
bob
casita
Vintage Casita window replacement / rebuild questions saucesquatch Problem Solving | Owners Helping Owners 15 12-20-2023 10:55 AM
Rebuild of 1988 Casita 16 EricAllyn Modifications, Alterations and Updates 231 08-31-2019 05:51 PM
1994 Gypsy Casita 16' rebuild saucesquatch Modifications, Alterations and Updates 30 10-15-2018 09:30 AM
1982 Fiber Stream Rebuild Victor Benz Modifications, Alterations and Updates 18 07-02-2015 01:55 AM
Wheel Rebuild for 1996 13' Casita Patriot Egghead Tim Care and Feeding of Molded Fiberglass Trailers 2 05-27-2014 04:37 PM
