Safety Chains On A Scamp 19 (5th wheeler)? - Fiberglass RV
Old 11-06-2020, 11:40 PM   #1
Nevada
Those of you with small 5th wheelers (scamp, escape, etc), do you use the safety chains and if so, where do you connect them? Thanks
Bfleissner is offline   Reply With Quote
Old 11-07-2020, 05:52 AM   #2
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Scamp sells/installs a proprietary hitch that uses a ball and a coupler. It is not a true 5th wheel because 5th wheel refers to the type of connection. Because the Scamp 19 attaches in the bed of a truck like a true 5th wheel, it is often referred to as a 5th wheel. Ball and coupler connections require safety chains, 5th wheel connections do not. Scamp’s modified 5th wheel hitch has provisions to attach the chains which are present on the Scamp 19. Those who use an Andersen hitch, another ball and coupler hitch requiring an add-on to the pin box of a true 5th wheel connecting trailer requires chains. I have seen different methods users employ to attach safety chains.
Old 11-07-2020, 06:49 AM   #3
Jon in AZ's Avatar
Short answer: yes.
The Scamp 19 requires safety chains because it is a ball and coupler connection. Escape and BIgfoot fifth wheels use a kingpin connection, so no chains.
I’ve seen three hitches commonly used: an older custom unit fabricated and sold by Scamp, a modified Reese unit currently supplied by Scamp, and the Anderson. What do you have?
Old 11-07-2020, 05:17 PM   #4
Weavery's Avatar
Trailer: Escape 5
Safety chains
I had a 2002 gooseneck Scamp (ball coupler) and used safety chains. There were holes drilled in the crossbar that held the ball on the mount in the truck. I was told to always cross the chains. The hooks on the chains went into the holes in the crossbar.
Jean
Weavery is offline   Reply With Quote
Old 11-07-2020, 06:48 PM   #5
Wayne53's Avatar
Trailer: Scamp 19
safety chains
I see from other posts that you have the reese hitch from scamp. The trailing edge of the top plate has two holes for hooking up the chains. I always use the chains and as the previous post states, always cross them.
Wayne
Wayne53 is offline   Reply With Quote
Tow safety chains on Scamp DogHaus Towing, Hitching, Axles and Running Gear 69 02-24-2014 08:23 AM
Safety Chains Too Short Steve Dunkel Towing, Hitching, Axles and Running Gear 3 06-17-2009 04:29 PM
Safety Chains Kevin K General Chat 1 03-25-2009 09:32 AM
Why you need safety chains... Bobbie Mayer Jokes, Stories & Tall Tales 0 05-04-2007 08:18 AM
Hitch test & Safety chains General Chat 0 01-01-1970 12:00 AM
