Extra step to install the lift kit
Note that the Scamps have a "tag" welded from the axle, up to the frame to reduce floor bounce. You could cut it and then lap splice a strap in with 4 bolts, or do it the hard way, I ground it off the axle then extended it by welding on a strap. Other than that it is a bolt on project. I measured from the brake plates to the front jack to get the axle square on the frame again. I now have about 9,000 miles on the modification. OH, JUST ONE MORE THING, THE OLD SCAMPS HAD A WELDED ON AXLE.
