scamp revamp (1993 16’) - Fiberglass RV
Old 03-29-2021, 03:52 PM   #1
Montana
Smile scamp revamp (1993 16’)
Hi, I’m Alex, I’m the proud new owner of a 1993 scamp 16’ and I couldn’t be more excited! The trailer is in great shape and just needs mostly cosmetic updates (it’s straight out of the early 90’s in there, but then again so am I).
Today i took a creeper for a look around the underside of the scamp and thankfully the frame and the OSB are in great shape. I only noticed one weak spot in the fiberglass up in the wheel well, i can access it pushing down from the fridge control panel too. Has anyone else had this issue? Wondering if i should try a fiberglass patch or if there’s a better way. The spot is tiny, size of a quarter or so.
I also plan to take out the old brown carpet and replace with cork flooring! I’ve seen plenty of floor replacement threads here that I’ll revisit and I am also open to any suggestions. One of my main questions is, when I have the carpet taken up and the glue scraped, is there a coat of some sort of paint I should be considering putting down underneath the floor underlayment while everything is already exposed?
Also..this is quite the luxurious idea..but has anyone had luck with those 12v heating element pads that roll out underneath flooring? I’m toying with the idea of installing one or two of those for when I’m connected to shore power
alexandra w is offline   Reply With Quote
Old 04-11-2021, 12:37 PM   #2
Borden's Avatar
Name: Borden and Carole
Welcome to the group Alex:
Take some pictures of your gem and post them so people can see what you plan. We all like to share.
Weight is usually important in any repairs: have added some weight in doing past repairs, the axle and tires have a limit. An example would be we upgraded to C rated special trailer radial tires (STr) but still have the axle limit to consider. Read on the site and ask questions of the group they will try to help
Our postage stamp in heaven.
Borden is offline   Reply With Quote
Scamp Revamp Project Imagarcia Modifications, Alterations and Updates 1 07-21-2020 08:20 PM
My first revamp TammyC. Problem Solving | Owners Helping Owners 0 07-06-2014 03:01 PM
Trillium Revamp peatle Modifications, Alterations and Updates 9 09-28-2012 10:02 AM
SOLD - 1993 SCAMP 16-Goshen,Ohio Greg A Classified Archives 3 05-25-2008 11:43 AM
1993 Scamp 16 lgreen Classified Archives 1 08-30-2006 08:46 PM
