05-28-2006, 04:18 PM
Guest
Hello,
I have noticed a number of photos with small cars (e.g., Volkswagen Beetles) paired with Bolers. We have a 1200 lb Boler (loaded for bear) that we currently tow with a Dodge Caravan - which is plenty big enough. We would like to downsize the vehicle for a number of reasons and are interested in either a TDI Golf or a new Mini Cooper. The dealers we have talked to say either "no problem" or that it will void the warranty. As far as we can tell, there is no official prohibition on towing.
I would like to hear from people who have towed bolers or equivalent with a small car about :
1. The practical problems doing this (ie, hitch installation, going up hills, stopping, etc...). I am not too worried about passing on the highway since we are always very cautious when we tow.
2. Any warranty or insurance issues you have come across. One dealer actually suggested that we remove the receiver hitch every time we bring it in for service so that the service guys wouldn't see it and void our warranty.
Many thanks,
Jeremy
05-28-2006, 05:07 PM
Trailer: 84 16 ft Scamp
We towed a 13ft Compact Jr. with a Peugeot Stationwagon in the mid-70's around the nation. The car had a 1.6 litre engine, about 65 hp, and weighed about 2000 lb.
We never had a problem with stability or braking. Had some cooling problems in the Utah desert in July. Had to run with the heater on for a ways up a long hill.
The biggest problem was a stop for a construction crew on a steep mountain pass. When the cars were allowed to go, our rig didn't have enough umph to get rolling. The construction fellows ran over and gave us a shove and off we went in low gear. There just wasn't enough steam available to shift into second, so it was first gear for what seemed to be about an hour until we crested the summit.
We are quite a little older now and hopefully wiser. I get the same fuel economy with a 16ft Scamp pulled with a full size GMC Jimmy powered by a 6.2 litre turbo diesel as with the smaller Compact pulled with the wimpy Peugeot. There is no point in even attempting to compare the ability of these two rigs for towing.
The real problem with the smaller cars, and pickups, is not that they don't have enough power, but that it is not available for starting off. To rectify this, they would either need to increase the cubic capacity of the engine significantly, or add a much lower gear for starting off.
I'm sure you get my point, but if I needed to limit myself to just one vehicle, I'm not sure I would want to herd two tons to the grocery store and post office all year just for the increased margin of towability it offered. I'd just enjoy the rig I had like we did 30 years ago.
Perhaps someone with more contemporary experience would chime in. Good luck and happy RVing.
05-28-2006, 05:17 PM
Trailer: 1975 13 ft Trillium
I have seen people in "our" area towing a 17ft. Escape with a 1929 Shay (which is a fiberglass replica). The roadster has a 4 cylinder Pinto engine with a C-3 automatic transmission. Yes this vehicle is "modified", but still shows how small a vehicle one can tow a trailer with. I know he has a larger rad, with an electric fan and a fair sized tranny cooler. The trailer also has e-brakes on it for safety! I have pix of it but I cannot figure out how to post here yet!!!
05-28-2006, 06:49 PM
Trailer: Trillium Manufacturing
The most important consideration is safety for yourself and others.
The only only way to be assured of that is to go by what the Car manufacturer says - IN WRITING.
No salesman, other owners, previous owners, uncles, or whatever will provide that. There are far too many variations of engines, transmissions, drive train type, HD options for anyone to have an accurate answer.
If you're buying a used car, ask to see the owner's manual. It will be stated in there.
If you're buying a new car, not only can you look at the owner's manual, but there is usually a chart in the showroom which will give you a quick summary. (You should still look in the owner's manual.)
Finally - and maybe most important - you can be the best driver, and be involved in a bad accident, which is not your fault. These days, smart lawyers will, and do, get you on the hook if you are towing something too heavy for the car.
Keep the highways safe. Tow with the right rig. And remember, this is one area where bigger is better.
By the way; I don't think a boler "loaded for bear" will weigh only 1200 lbs. I would get it weighed at a couple of different places.
Tom
TrilliumRV.com
05-28-2006, 08:31 PM
Trailer: 1991 16 ft Casita Freedom Deluxe
If I had to pick from the two choices you listed, I'd go for the Golf TDI every time. Diesel torque is where it's at!
Not sure what the official word from VW America is, but I wouldn't be surprised to hear that trailers of the same size are regularly towed with a Golf in Europe. If I were to attempt it, though, I would definitely want trailer brakes.
I have a '98 Jetta TDI and while I don't have a hitch, I wouldn't hesitate to tow a light trailer with it.
05-28-2006, 08:39 PM
One dealer actually suggested that we remove the receiver hitch every time we bring it in for service so that the service guys wouldn't see it and [b]void our warranty.
Finally - and maybe most important - you can be the best driver, and be involved in a bad accident, which is not your fault. These days, [b]smart lawyers will, and do, get you on the hook if you are towing something too heavy for the car.
Enuf said.
Frederick - The Scaleman
05-28-2006, 08:48 PM
Trailer: 2004 Scamp 13 ft
I'm with Tom - READ THE MANUFACTURER'S RECOMMENDATION - I've got a pretty small car and I've thought very carefully about how far, where, etc.... and I figure the Pontiac people aren't looking for any liability and I must be in some sort of safety zone...
I also compared hp, wheelbase length, vehicle weight and torque to comparable vehicles that were towing successfully...
after lots and lots of MATH and a little bit of faith, I think I can SAFELY tow a 13'er if I don't go crazy packing...
Now the Big Dog and I must lose 10 pounds a piece and I think we will make the limits!
05-28-2006, 11:58 PM
Towing isn't just about getting started or pulling; it's also about steering control and stopping. If the wheelbase, the tranny, the rear end ratio, the suspension, the cooling, the brakes, the tires, the body strength and a number of other things aren't right, it can be a receipe for lots of repair money or a highway accident.
Most automotive salesmen will tell you that their product will pull your RV and most RV salesmen will tell you that your vehicle will pull their RV -- Ask to see the manufacturer's tow ratings in writing (For those salesmen who don't know how to find it, it's in the Owners Manual).
There are a lot of folks out there towing with not the right stuf and I believe it's "So far, so good"... When the bad stuf happens, it happens fast.
05-30-2006, 07:15 PM
Here's a link to a VW with enuf power to tow an Airstream up Pike's Peak, but is otherwise unsuitable for towing an Egg (or getting the Airstream back down again):
Powerful VW
05-30-2006, 07:23 PM
Maybe a [b]Hard Boiled Egg...
05-31-2006, 09:28 AM
Hey, watch that mouth. (note signature)
06-01-2006, 05:34 AM
Trailer: Boler 1984
Almost anything can be used to tow these lightweight trailers...... But can you stop it?
06-01-2006, 02:29 PM
Trailer: 1979 13 ft Boler and 1987 Bigfoot 5th Wheel
I can't imagine towing anything with a mini cooper but I did a quick search and there is some info out there about folks who do it. Heck I worried about towing with a Ranger.
1979 Boler B1300 | 1987 Bigfoot 5th Wheel | 1988 Bigfoot 5th Wheel | We officially have a collection!
06-01-2006, 03:26 PM
Since you can probably put a Cooper inside one these FG trailers, I'm not so sure I'd want to be on that stretch of road if it's towing something.
On the other hand, as a film promo for Trillium, I towed it once with a 750 Norton motorcycle for a short stretch. It worked - even without brakes on the trailer! Does this count as a recommendation?
Tom
TrilliumRV.com
06-01-2006, 11:34 PM
Trailer: 1985 Scamp 16 ft
(Quote) - We have a 1200 lb Boler (loaded for bear) that we currently tow with a Dodge Caravan - which is plenty big enough. We would like to downsize the vehicle for a number of reasons and are interested in either a TDI Golf or a new Mini Cooper.
I'm sure that our Golf TDI would be an adequately powered vehicle for such a lightweight. Our tow car, a Subaru Forester, has the a similar torque output, but not the turbo, which really gives the TDI extra punch at altitude. That said, I never considered the Golf as a tow car. Compared to the Subaru, it has two big defiencies. Obviously, it's front wheel drive, which is probably the least-favored match with a trailer. With AWD, I never worry about getting stuck. More importantly, the TDI lacks adequate ground clearance for suburban use, much less the forest service roads and backcountry where I hope to go. The A4 models like mine (1999-2005) have less than 4 inches of daylight below their fragile alloy oil pans. Older and newer model Golfs and Jettas have considerably better clearance, but most TDIs on the road now are the middle models. I can't speak to the Passat, but that's a heavier car to haul with the same engine, and most of these are crippled with automatic transmissions.
If I were you, I'd test the waters. Buy a '97-98 Jetta for $6 grand and tow with it awhile. If it meets your needs, keep it, but if not, you'll always find another buyer. Then go get a Forester, which will give you a significant mileage boost --mine gets 18 mpg towing at 60-65 mph and 25-28 unhitched, on the open road. And it's closer to the size and fun of the Mini, compared to your Caravan.
