Uhaul owners Heads up - Fiberglass RV
Old 09-10-2012, 02:01 PM   #1
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Finally got around to replacing the front two missing Elevator bolts that hold the trailer to the frame this weekend. Since the existing ones were 1/4 20 x2" I upgraded to 5/16 16X2". I punched out the heads of the two that were missing at the frame and found that they had broken off due to corrosion.Since I was going to replace the rest any way I didn't think too much of it as the front gets a lot of water etc. Well to make a long story short All but one of the rest were ready to go. As I attempted to break the nut loose the bolt sheared on all but one. I replaced two of those that rundown on each side of the centerline and they were fine just a little rust. Pictures enclosed for your your amusement. I suspect the perimeter holds more water which wicks into the plywood and facilitates teh corrosion as it looks to occur in that area. New ones were installed with a big dab of the dreaded silicone rubber to make a gasket.I guess it is still pretty good to have lasted 28 years.
Michael j.
mmeyer is offline   Reply With Quote
Old 09-10-2012, 02:35 PM   #2
Trailer: 1984 U-Haul CT-13
wow! looks like i'll be adding that to my list!
themik is offline   Reply With Quote
Old 09-10-2012, 02:38 PM   #3
Thanks for posting that, I'll check mine. Another thing I'm going to look at is the bolt through the tongue to the frame. Bob
Old 09-10-2012, 03:33 PM   #4
Thomas G.'s Avatar
I found two broken in the front on mine. Now I need to go check the others.
uhaul
New UHaul Owners, the rPad2 Jane SC Hi, I am.... 25 02-09-2012 08:34 PM
Attention Uhaul owners CindyL Classified Archives 11 01-04-2011 09:29 PM
