Cute "little" kitchen faucet from Home Depot. It is used at your kitchen sink for filtered cold water only. Perfect.
For those of you who have taken the LP Gas tank off, I used the remaining steel on the tongue to hold the spare tire. Just drill holes for 12 inch long, 1/2 inch galvanized bolts.
Took the stove out and put in a new Coleman camping stove. Uses the short fat LP Gas bottles and goes outside very easily. It stays put on the counter when driving even over big bumps.
In the next picture, note the four short round legs (cut from closet pole). They are the legs outside on the table and hold it in place inside. Look in the hole to see plywood on top of the icebox. This allows two more plastic dish pans for food storage.
Old stove top metal base (with plywood added) to cover hole when stove it outside.
If you have the original 13 inch
steel wheels for your
UHaul CT with 3 tiny nubs (bumps) on the inside the wheel flange there are brand new
baby moons and trim rings you can order. They fit perfectly. They are part number RC2M (
Baby Moons) and TR16SF (Trim Rings) from
www.hubcapmike.com.
