shower problems scamp 19 - Fiberglass RV
Old 11-09-2018, 09:37 PM   #1
Trailer: Scamp 5th wheel
Water splashes out of my shower when moving. Is there suppose to be a check valve or something to prevent this?
patsublett is offline   Reply With Quote
Old 11-09-2018, 10:01 PM   #2
Borrego Dave's Avatar
Might give us a bit more info....where's it coming from, pan, shower head or toilet?
Old 11-09-2018, 10:17 PM   #3
Appears to come from the drain and collect in the pan
Old 11-09-2018, 11:40 PM   #4
Dennis mn's Avatar
Minnesota
Our Scamp did the same thing until I got a rubber stopper for the drain. Our Airstream was provided, from the factory, with a stopper to prevent the issue.
2021 Nissan Pro 4X. 2020 Scamp 19’ Deluxe.
Dennis mn is offline   Reply With Quote
Old 11-10-2018, 12:19 AM   #5
Glenn Baglo's Avatar
You don't need anything as complex as a valve. Escape has a stopper that screws into the drain. The water in the P-trap is sloshing around during travel.
All you need is a drain plug.
Old 11-10-2018, 04:12 AM   #6
As others have mentioned, a drain plug would work. I don't have a Scamp but if I remember correctly, there is a water pump switch to push the water from the shower pan to the grey tank because the tank is higher than the pan for drainage. Might be that the plug is also needed even with the plug. Wonder if a straight line HepVo valve would fix that.
Old 11-10-2018, 10:18 AM   #7
floyd's Avatar
Scamp uses a screw=in plug like the one shown below.
Also you might check the grey water filter under the trailer and keep it clean so the pump can do its job more efficiently.
Old 11-21-2018, 11:28 AM   #8
Jim Bago's Avatar
Trailer: 1987 19 ft Scamp 19 ft 5th Wheel
We have one of the older 19 footers. We had to retrofit the pump and filter to the shower to solve the problem.
Jim Bago is offline   Reply With Quote
Old 11-21-2018, 02:45 PM   #9
Shower drain valve
My 2006 Casita has a push-pull valve handle that you can operate from the outside front, between the drain and the P-trap. In my case it's a little hard to get at the valve, so take a good look for one on your Scamp. If there is no valve, I agree with the others that getting a good drain plug would be the easiest way to go.
The only problem with the outside valve is if you forget to open it before you start taking a shower, you'll be filling up your shower pan!
vanstaats is offline   Reply With Quote
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Scamp towing problems with Toyota Tacoma pickup Doris Towing, Hitching, Axles and Running Gear 21 11-07-2009 05:58 AM
Scamp Window Problems Parker Buckley Problem Solving | Owners Helping Owners 5 01-26-2008 11:29 AM
Scamp towing problems with Toyota Tacoma pickup Doris Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
