Scamp threshold gasket replacement? - Fiberglass RV
Old 07-23-2020, 07:11 AM   #1
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
I'm replacing my door orginal seals on my 2007 13' Deluxe with the current seals sold by Scamp. I have the door surround completed and have the threshold old seal removed and completely cleaned up ready to install the new threshold seal purchased from scamp. I was surprised to find a 6" black flat metal bracket under the old seal at the bottom right corner of the door opening. This bracket does not fit flat against the body.
My question is-- does the new threshold rubber fit over this bracket or should I try to squeeze that portion of the seal onto the metal threshold strip leaving the bracket exposed? If I run the seal over the bracket, half the tape on the seal will be on the bracket and half on the threshold metal frame for that 6" causing that corner to stick out more than the rest of the seal.
As I didn't expect to find that bracket at the bottom of the door I didn't pay much attention as to how the orginal foam seal fit on that corner. Appreciate any input from those that have replaced this seal or have a new Scamp, assuming the new trailers have this bracket on the door, as to how the seal fits from Scamp.
Thanks in advance!
_________________
2007 Scamp 13' deluxe
RSchleder is offline   Reply With Quote
Old 07-24-2020, 05:05 PM   #2
Called scamp, they said to put the threshold seal directly over the bracket. Well, after looking carefully at the threshold, threshold seal, where the door gasket aligns on the threshold gasket ends, I chose to mount it slightly higher on the threshold bracket end. I also cut a small notch in the backside of the gasket on each end so it fits tight against the plastic door edging as well as fiting snug against the vertical portion of the door seal on both ends.
Old 07-24-2020, 05:07 PM   #3
Called scamp, they said to put the threshold seal directive over the bracket. Well, after looking carefully at the threshold, threshold seal, where the door gasket aligns on the threshold gasket ends, I chose to mount it slightly higher on the threshold bracket end. I also cut a small notch in the backside of the gasket on each end so it fits tight against the plastic door edging as well as fitting snug against the vertical portion of the door seal on both ends.
Old 07-29-2020, 12:02 PM   #4
Nebraska
yep; methinks you got it right...
I'm a couple of weeks ahead of you on this... I put a new door gasket on my 19' Scamp in June. Otherwise I would have benefited from seeing your post.
I first tried doing it behind the bracket on the door, and then realized I needed to mount it on the bracket. In the end, I cut it about 1" or 1 1/2" too short. That doesn't seem to be a problem, but, again, I would have benefited from the info you just put out for all of us. THANKS!
BTW: It takes awhile for the new gasket to compress a bit, making the door hard to close. After struggling for a month or so when closing it, it's finally closing fairly reliably. I know I've seen some posts about those who have shimmed their door, but I think one needs to give it a month or so to let the gasket compress, and then decide. (Of course, if you can't close the door at all, you probably need to shim it).
RaceEasy is offline   Reply With Quote
Old 09-13-2020, 06:47 PM   #5
At first it was very difficult to close the door with the new gasket in place. After 2-3 weeks, the gasket compressed and the door closes nicely with a good seal that will not leak. I agree with your statement -- anyone installing the new door seal from Scamp, you need to wait a couple of weeks before you start modifying your door or hinges. Give it a bit of time and you will like the results!
Amerigo Threshold Gap Issue JonnyX151 Modifications, Alterations and Updates 2 05-14-2020 07:32 PM
Scamp Screen Door Doesn't Stay in Threshold barryra Problem Solving | Owners Helping Owners 3 07-10-2017 11:46 AM
Boler Door Threshold Cat futrell Problem Solving | Owners Helping Owners 0 01-18-2013 01:36 PM
entrance door jamming on threshold! Kenny Strong Care and Feeding of Molded Fiberglass Trailers 0 03-24-2012 11:50 AM
Uhaul doorway threshold? Jamey Problem Solving | Owners Helping Owners 7 02-10-2007 09:41 PM
