My best add-on: Air conditionned in my U-haul CT-13 - Page 5 - Fiberglass RV
Old 09-02-2015, 08:43 PM   #81
Trailer: Scamp - "The Haunted Mansion" (13') and TBD (16')
Thanks for the pics of the deflectors! We will have to do that when we get back from our weekend trip.
Sohkraites is offline   Reply With Quote
Old 09-03-2015, 05:45 AM   #82
Trailer: Uhaul
Thank you so much for all your help! I am going to begin the A/C install today.
I have a question about the drain underneath...from your picture, it appears that you added a 90 degree adapter and a length of PVC? Where does it go? Why not allow it to drain straight down?
Uhaul Mike is offline   Reply With Quote
Old 09-03-2015, 06:09 PM   #83
Trailer: Uhaul
Dan?
I am not trying to be a pest, but can you tell me what you used to make the black "cup" that catches the runoff condensation water?
Old 09-03-2015, 06:50 PM   #84
Youhauler's Avatar
Trailer: U-Haul CT-13 1985
Quebec
Originally Posted by Uhaul Mike View Post
Dan?
It is a ABS reducer with a thread on the small hole.
Youhauler is offline   Reply With Quote
Old 09-03-2015, 07:35 PM   #85
Carol H's Avatar
NICE well thought out work Dan!! Love it when an owner does a mod that fits in so well and doesnt look like a major after thought!
Old 10-07-2015, 10:54 AM   #86
MoDZuKi's Avatar
Trailer: Trillium 13'
Hey Dan I have an Air con unit that I am modding also for this purpose. Instead of putting the holes in the side- would it not be just easier to put them in the bottom?. Opinions?..Actually after looking- I am going to rip out the furnace from my trailer (1976 and I don't trust it) and install the air conditioner right there - I can then utilize the vent hole/grating that already there for one of the vents. Would you say its best to use that for the hot air or cold?.. I'll add a 6" for the other probably in the floor and separate the air flows..
Cheers Dave
MoDZuKi is offline   Reply With Quote
Old 10-07-2015, 02:48 PM   #87
Youhauler's Avatar
Quebec
Cheers Dave
Hi Dave,
It could work if the air flow for the inlet and outlet are on the floor. However, I am wondering how you will block these holes when the A/C is not in function. Personnaly, I like the fact that I can seal these holes when the A/C is not in function. I prevent mud and dust to penetrate in the unit.
Old 03-19-2020, 06:01 AM   #88
Trailer: Uhaul
Electrical connection.
Great mod. I am currently wiring my ct13 with a PD4045. Can I ask where you located the outlet for your ac? Not a lot of space! Is it on a dedicated circuit? Ampler for breaker? Wire size?
I also wonder about using the space for a portable heater in winter, does the ac remove easily?
GregoryP is offline   Reply With Quote
Old 03-19-2020, 09:22 AM   #89
Youhauler's Avatar
Quebec
Can I ask where you located the outlet for your ac? On top of left side using a surface mount standard outlet box glued with PL.
Is it on a dedicated circuit? Not yet but I am planning to install a separate breaker.
Standard #14 as the AC cunsume less than 15 Amps.
Does the ac remove easily? Not really. It is installed to stay permanently.
Old 03-23-2020, 12:58 PM   #90
Trailer: Uhaul
Thanks for the info. I am doing the install now and am thinking about a slightly different option, but it is always great to see what thoughtful people have done. Since I was hoping to put an external outlet on I hope that by adding it to the outside corner of the space I can use the port as a feed for an extension cord. If it works I will share.
u-haul
Air conditioner add? Tom Myers Problem Solving | Owners Helping Owners 7 09-03-2015 04:46 PM
Air conditioer installation in Cloud/Burro/U-Haul DonDeutsch Care and Feeding of Molded Fiberglass Trailers 6 07-08-2010 07:17 AM
best technique for air flow with Maxx Air Fan with 13 footer lloyd cicetti General Chat 4 06-18-2010 05:04 PM
Add Solar Air Conditioning Bigfoot Mike General Chat 8 02-24-2007 12:09 PM
Add On Air Conditioning Idea Patrick M. General Chat 1 08-20-2006 11:38 AM
