changing scamp wheels - Fiberglass RV
Old 04-15-2019, 04:59 PM   #1
Trailer: in the market
what are the smallest wheels / tires I can substitute on a 13ft scamp to lower it for clearing the garage door about 4" or more ?
silvio suarez is offline   Reply With Quote
Old 04-15-2019, 08:42 PM   #2
floyd's Avatar
The brakes on a13Scamp are 7" ...
an 8" wheel will bolt right on. They make them in both bolt patterns.
Old 04-16-2019, 08:13 AM   #3
Drop it on a set of car rollers with no wheels and it probably will still be too tall.
Mine would not go under a 7 foot door even with the rollers.
No AC, only the escape vent on top.
Your mileage may vary.
You could try those 8" wheels with no tires as well.
Good luck!
Old 04-16-2019, 12:25 PM   #4
Yep...the post-fire Scamps were manufactured taller so I believe that eliminated 7'-door entry especially with ANYTHING on top. (Floyd can tell you how much...I'm thinking 6" or to a 6' interior height). The #6 just stands out in my mind
I had a "carport" put up and while it DOES keep the sun off of it, it's still amazing how "dirty" my Scamp gets! A garage is DEFINITELY the best storage hands-down!
Old 04-21-2019, 10:06 PM   #5
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
I have a 7-foot door and the only way I can get my 16' in the garage is to take off the wheels and roll it in on the brake drums. I lay down a long strip of carpet for them to roll on. It sucks but it's better than it being outside.
Bryan L. is offline   Reply With Quote
Old 04-23-2019, 03:34 PM   #6
scamp wheels
thank you
Old 04-23-2019, 03:34 PM   #7
thanks for the info
Old 04-23-2019, 09:03 PM   #8
floyd's Avatar
post fire height increase was officially 3"
More news 2019 Scamp13s now use a Zero axle with 10" brakes...Results are a couple inches more overall height Not sure of exact number.
Old 04-24-2019, 06:48 AM   #9
Jon in AZ's Avatar
Does that mean they’re now using a 3500# axle (presumably de-tuned to something closer to the actual GVWR)?
Old 04-24-2019, 10:28 AM   #10
Trailer: scamp 13
VA
Those who roll their trailers into garages on the drums: do you get the weight off the drums while stored? Does it make any difference if you do/don't?
Auto parts people say drums on shelves must be stored laying flat or they will warp from their own weight.
SamMoore is offline   Reply With Quote
changing sink trap-1994 Scamp jessesouza Problem Solving | Owners Helping Owners 12 10-09-2023 05:08 AM
Changing out 13" wheels for 15" wheels Ed Morris Towing, Hitching, Axles and Running Gear 3 01-26-2018 05:14 PM
Replacing axle, adding brakes, changing wheels? Zennifer Towing, Hitching, Axles and Running Gear 12 03-06-2016 11:35 PM
Changing Casita to 15-inch wheels Ed Brocksmith Modifications, Alterations and Updates 12 11-30-2015 08:47 PM
Changing rims on 13' scamp DavidS Towing, Hitching, Axles and Running Gear 3 08-08-2009 06:55 PM
