Battery upgrade on my Bigfoot 21RB - Fiberglass RV
Old 07-04-2019, 06:03 PM   #1
I haven't done any off grid camping yet but just testing the battery in my driveway the battery hardly lasted at all running almost nothing. Few hours of leaving my fantastic fan on would just about drain it. So I wanted to do some good testing and got a 180 watt portable Zamp solar panel. I charged the battery 100% (12.71V) and disconnected the battery. The battery was at 12.6 the following day, a week later and it is at 12.43V. It has not been connected to anything since it was charged. I contacted the manufacturer of the battery (Centennial Deep Cycle DC24RVM non sealed Lead Acid) and it turns out this battery is 75ah. Kind of lame for a 21' Bigfoot. Not sure if that is how it was sold, and the first owners just ran on the grid, or if the first owners of the trailer had better batteries and used them in their new trailer so they threw this one in.
So now I need to decide if I'm going to upgrade to a set of sealed deep cycle AGM batteries, or just go full on with a lithium conversion like Jon Vermilye did here:
http://www.fiberglassrv.com/forums/f...ium-89150.html
I'm kind of a gadget geek so having lithium seems pretty neat, but I'm still not 100% convinced I'm going to keep the trailer. I love it but it seems just a bit too big. Towing it with my Colorado is ok but not super fantastic. Really I'm still getting use to towing so with some more practice I may find it's ok. Adding 2 decent AGM batteries is going to add a lot more weight than the lithiums, and I guess if I do end up selling it, having upgraded the batteries wouldn't be a loss since I could add it into the cost of the trailer right? Either way I go, I am pretty sure there is enough room for the batteries. There is a large area in the front under the cowl behind the propane tanks. 2 batteries should fit great there.
Mostly maybe I'm just venting I guess, much like my poor little 75ah lead acid battery.
JonRaw is offline   Reply With Quote
Old 07-04-2019, 06:11 PM   #2
member
Isle of Wight
Sounds like a bad battery - should only lose a few percent a month disconnected.
There are 2 group 24 12V in parallel under the nosecone of my Bigfoot 17.
They last for days running fans/lights/water pump.
They last for ever with a 100w solar panel.
Jim
WizWid is offline   Reply With Quote
Old 07-04-2019, 07:31 PM   #3
Steve Hammel's Avatar
Trailer: Trillium 4500
I was going to convert my Oxygen to Lithium. I found a 2 pack of Lithium batteries at Amazon delivered for approx. $1500. The problem then is you need to convert your convertor for the lithium. A regular convertor can burn them up if you're not careful.
I do like the idea of going lithium as my new Hymer has a 12v compressor fridge. After I get it I'll check everything out and make the determination at a later date.
In your case I'd just upgrade the battery, use it for awhile, and then determine if you want to go through the expense and trouble. In my opinion very few future buyers would even know the difference in battery types and chances of recovering your investment would be slim.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe, Casita 16.
Steve Hammel is offline   Reply With Quote
Old 07-04-2019, 09:44 PM   #4
John in Santa Cruz's Avatar
Mid Left Coast
if the batteries are mounted on the hitch, I'd consider upgrading to 2 x 6V GC2 golf cart batteries in series, this would get you like 220 AH give or take, which if you go by the max 50% discharge for best battery longevity, gets you 110AH usable, which is about 1300 watt*hours. I would go for wet cells for an RV application, as there's no risk of the battery tipping over or whatever, and a tongue mounted battery doesn't need special venting.
Old 07-04-2019, 09:54 PM   #5
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Losing a little voltage while sitting is not the same thing as very limited capacity. It sounds like your battery is sulfated. This will make it quick to charge up and reduce it's capacity, in some cases to near zero.
You can run a load test at an auto parts store to see if it has the rated capacity.
Good or not, one 75 AH battery is very small.
Since you are not sure if you want to keep the trailer, put (2) 12V Group 24, or better yet, (2) 12V Group 27 deep cycle flooded or maintenance free batteries, if they will fit. Or, as John suggested, get two 6V bats and wire them in series. I think I'd prefer the 12V batts in case one goes bad. Either setup will give you a significant increase in performance.
Be sure to keep the new ones charged to prevent them form getting sulfated.
Raspy is online now   Reply With Quote
Old 07-04-2019, 10:11 PM   #6
Mid Left Coast
in general, the 6V golf cart batteries are true deep cycle, most 'marine/rv' batteries are not.
Old 11-06-2019, 02:28 AM   #7
After seeing a recent thread on manners it occurred to me that I never closed the loop on this or even thanked everyone for their replies. Very rude of me and I apologize. Thanks for your input everyone. I did take your advice into consideration. After a lot of web searching and youtube videos on the subject, I ended up buying 2 Battle Born Lithium batteries. I had to start a new thread on the mounting of said batteries here:
Bigfoot Lithium upgrade - Fiberglass RV
Old 01-23-2020, 06:13 AM   #8
You may want to check out handy bob solar blog. It will definitely help you.
zorrou812 is offline   Reply With Quote
Old 01-24-2020, 11:54 AM   #9
OCJohn's Avatar
Trailer: Hymer
I love that guy. He’s a curmudgeon but has a very practical way of looking at things: proven, durable technology of good value is his status quo until proven otherwise. He’s got a good BS detector for products and technology that generate more hype from profitability than track record. He keeps things in perspective. His presentation of knowledge is a little scattered, so he’s better read like a novel than a quick reference. Worth the investment, though. My solar system is based on his recommendations:
2 260Ah 6v industrial deep cycle batteries
2 160w solar panels
Trimetric battery monitor with Bogart SC-2030 solar charge controller
#6 cable
https://handybobsolar.wordpress.com/
OCJohn is offline   Reply With Quote
Old 01-24-2020, 04:48 PM   #10
Yeah, he's great. I am trying to absorb it all and implement on my recent Bigfoot purchase. He will save me from some mistakes I think.
BTW I see you own a Hymer. My wife is German and we have visited their home town in Bad Waldsee Germany. Her family is just down the road. They even have a museum that is a lot of fun if you are ever so inclined.
Old 01-24-2020, 05:26 PM   #11
OCJohn's Avatar
Trailer: Hymer
Yes indeed - that’s on my list next time I’m in Germany!
Old 01-24-2020, 09:21 PM   #12
ThomasC's Avatar
Trailer: BigFoot 25B25RT
Massachusetts
Hey thanks for this. That is a great site.
ThomasC is offline   Reply With Quote
Old 02-21-2020, 02:57 AM   #13
Thank you for the suggestion. While I can see how it might be helpful for others, I didn't find it useful. I found some things about his blog that I strongly disagree with.
Old 02-21-2020, 07:52 AM   #14
Missouri
since you have been to Germany
We have been to Europe 8 or 9 times we take our tent and camp out! So much fun are you familiar with camping in Italy and parts of France where the people from the Netherlands come up to camp for as much as 3 months?
While there we noticed many interesting campers and their method of parking their trailers. They turn them all sideways and the heavy guys they use a power mover they keep in the trunk of their Mercedes. Another interesting thing!
I am always amazed by all this and just find it entertaining watching them and their processes.
bob
Old 02-21-2020, 10:08 AM   #15
OCJohn's Avatar
Trailer: Hymer
lol - you’re not alone. I just like his solar/battery info and skip past his thoughts on climate science.
Old 02-21-2020, 05:04 PM   #16
ThomasC's Avatar
Massachusetts
He is quite old fashioned and if you wanted to use lead acid he is probably spot on. The part I found most interesting is how much shadows effect the performance of solar panels.
battery, bigfoot
CA | 1993 Bigfoot Trailer 17' (Sale Pending) jflug Classified Archives 7 11-02-2014 10:55 AM
My New Bigfoot 21RB GeorgeR Modifications, Alterations and Updates 17 04-26-2008 12:35 PM
LCD TV for in Bigfoot 21RB GeorgeR General Chat 0 12-14-2007 08:18 PM
My New Bigfoot 21RB GeorgeR General Chat 0 01-01-1970 12:00 AM
