08-15-2019, 08:44 PM
Trailer: Bigfoot 17ft 1983
Bigfoot 17 longer tongue
Well, I finally got tired of being unable to drop my tailgate with the trailer connected to my truck. Also reckon that reversing will be a little more predictable with longer tongue. I'm pretty good at backing up my boat, and other trailers, but find this 17ft trailer being so wide for its length to be a bit vague until it's off to one side.
Without any true rationale I decided 15" would be the ideal amount of extra length. I cut off the coupler just in front of the jack mounting plate. Welded in a length of 3x3x1/4 tube. Plated over those welds with some 2x1/4 flat bar. Plated the bottom with some 5x1/4 flat bar. I used my 230 volt flux core machine at home so welds aren't beautiful but are plenty strong. When I have time in the near future I'll take it to work, grind off the paint and do another pass with our 480 volt Miller using 25/75 gas. That will give me a nicer finished bead, but for now its solid and serviceable. I forgot how smokey fluxcore wire is!
Heading out camping this weekend at Lac Le Jeune, so 'll try to remember to follow up with impression on whether the difference is noticeable between just providing clearance for tailgate......
08-15-2019, 09:12 PM
I wanted to do the same with mine, but never di. The only downside I could see for me was that it would take up more of my somewhat limited driveway. I think you'll like what you did.
08-16-2019, 12:06 PM
It occurred to me that a hitch extension (like those used with truck campers) might be a solution if you have more tow vehicle than you need. Then it could be removed for storage.
08-16-2019, 12:09 PM
Trailer: Lil Snoozy
Maryland
fold away tongue
Nice install. Will that lower the weight on the tongue?
I have been thinking about adding some tongue length to the Snoozy which is already a little longer than most because it is on a boat trailer. One thing I was thinking about doing was adding a fold away tongue so it wouldn't be so long when stored. Wondering if anyone has experience with them and movement when towing. Just thinking out loud.
Thanks, Doug
08-16-2019, 02:13 PM
Trailer: Roamer 1
Smith Valley, Nevada
Thanks, Doug
Or a telescoping one. This might be easier to make while being strong. Early Olivers have this style, and one cross bolt is all you have to remove to pull it apart. That feature also acts a a good theft deterrent. Plus, a telescoping one can easily be adjusted for length.
Long tongues, that allow opening the tailgate while hooked up, are very nice.
08-16-2019, 02:20 PM
I have a fold away Fulton hinge on my boat trailer and while it is fairly robust, I wouldn't add it to any trailer I pull on forestry roads as I believe a solid tongue is less likely to have issues with the stress that results from vibration and dynamic loading on gravel.
I have way more tow vehicle than needed, and zero concern with tongue weight ( 3500 Cummins diesel) but did not want to do an excessively long draw bar as moving your ball (pivot point of trailer and truck) farther back from your rear axle really changes towing characteristics.
08-16-2019, 07:01 PM
Also, the suggestion of a telescoping tongue is a great one. In my case I wanted to retain my A-frame jack which would prevent the passage of a long telescopic tongue. We have a long driveway so it's not an issue.
The boat however JUST fits in the garage and the addition of the hinged tongue allows me to keep my workbenches at the back with about 2 ft of working room on either end of the boat. The hinge works fine but makes me hesitant to tow it long distances, where I think I'd feel more comfortable with a telescoping design. I may consider that as a winter project.
08-16-2019, 08:42 PM
Trailer: Roamer 1
Mike,
I don't see why you couldn't either make a new mount for the jack, that set it off to one side and a bit rearward, to clear a telescoping tongue, or get a jack that mounts on the side of the tongue. The Oliver style sets the jack back and to one side, while Black Series brackets it onto the outside of the tongue rail. If you can't move it back, because of the propane tank, then outside is fine.
08-16-2019, 10:10 PM
The short answer is I don't have a need on the Bigfoot trailer to have the tongue collapse or swing for storage space, so I prefer the simplicity of a rigid, welded tongue. We have ample storage length in our driveway.
08-17-2019, 07:30 AM
Lengthening the drawbar rather than the trailer tongue is bad for towing stability. In general you want the rear-axle-to-ball distance as small as possible. Truck campers often tow boats, which are naturally more stable than travel trailers.
The OP’s solution is the better one.
If it’s just about tailgate clearance, a removable tongue jack is another possible solution. Google Jack-E-Up.
08-17-2019, 12:28 PM
Trailer: 2014 Lil Snoozy
Nice job. Should make backing easier.
08-19-2019, 09:15 AM
Trailer: Sasquatch
Montana
I had a top-wind tongue jack, and it needed to be replaced. I figured a side-wind would be easier to wind, so I bought one. It is easier to wind, but now I can't drop my tailgate all the way. With the top wind, I could easily get it open by keeping the handle rotated back toward the trailer. With the side wind, which can only be installed with the handle on the truck side, I can get the tailgate down all but about 2". That works for grabbing stuff, but I know I'm going to end up with a dent on my tailgate.
Nice mod, though. My only real trailer experience is with my Bigfoot, so I don't have anything to compare it to. Other than the tailgate thing, I don't have any issues. But since I'd eventually like to spruce up the exterior, and my tongue (like the rest of my frame) has a lot of superficial surface rust, I've considered getting a new one put on there. If I do that, I guess I should consider a longer one.
I can paint the rest of the frame with POR 15 or something, but the tongue would be tough since it has moving parts.
08-19-2019, 09:01 PM
You could install a folding sidewinder. I have one. It tucks alongside the frame out of the way.
08-20-2019, 08:57 AM
interesting....
not knowing how much of that 15" extension you actually needed to drop the tailgate...it occurs to me that another fix would have been a longer stinger...looks like your truck would have handled the little extra weight/leverage easily.
another factor/result with a longer stinger is that the trailer would more closely follow the truck around corners...at the start of the turn the ball moves in the opposite direction of the turn...a longer stinger amplifies this effect (greater distance between the rear wheels and the ball...
I found this out sort of by accident when I had to tow my 26 foot boat with a new vehicle once...late on friday afternoon all I could find was a longer than I wanted stinger....I had to buy it and planned on cutting it down the following week....I never did...the boat was way easier to move around corners (followed the trucks tire tracks way more closely...never had to swing way out at intersections to avoid hitting the inside curb with the trailer wheels)
I started towing boats too and I can relate when you say towing/backing up the BF seems like a real challenge compared to boats...with a boat you can see your wheels clearly and detect the start of a turn right a way....not so with that big flat slab of FG 8 feet wide....
I somewhat solved that problem by affixing targets on the trailer...just two pieces of black elec. tape...when the rig is in a straight line, sitting in the truck I can just barely see both targets in my rear view mirrors...as soon as the trailer starts moving to one side or the other I see it INSTANTLY in my mirror(s)...and can "chase" the trailer a lot better (before it gets too far out of alignment)
I also put a target at the center of the trailer...with a target stuck to the inside of my rear window...used as reference points when I'm backing up to hook up the trailer
08-21-2019, 02:46 PM
Trailer: Casita SD 17'
How I got my tail gate down much easier than welding
Get the Jack E Up.
No welding, easy to remove jack so you can open the tailgate with the trailer attached. For me it was a no brainer
08-22-2019, 08:42 AM
Trailer: Sasquatch
Montana
I didn't realize this was such a common issue. Mine was never in the way when it was top-wind, and actually it wasn't in the way when I first installed the side-wind, either. Not until I put new leaf springs on my truck and changed the geometry back there. I had to flip the hitch coupler so it was slightly lower than my bumper to get my trailer level, and that's when the handle started getting in the way of my tailgate.
10-13-2019, 10:02 PM
Well, after two trips with it, I'm pleased with the results. It tows and better and reverses more predictablely with the longer tongue. I also welded up two spare tire carriers, welded them to the bumper and tied them back to the frame with some lengths of 2x2 box tube. Wheels are from a 2005 Ford Explorer which have correct bolt pattern, and center bore large enough to pass over hubs. Track width works well despite wheels being different offset than trailer rims. Very stable. Tires are 245/7/R16, which is a little bigger than I wanted but came on the rims and are in useable shape for a couple of trips. I'll replace them this winter with some better suited tires when I come across a deal.
10-14-2019, 08:52 AM
Trailer: Sasquatch
Montana
Glad to hear you're getting good results.
That looks like a really nice setup. Do you have a straight axle and a sprung-over setup? Looks a couple inches taller than my Bigfoot. I have a straight axle, but sprung-under. Plenty tall for me but I'm sure a few more inches of clearance helps every now and then.
10-14-2019, 12:18 PM
Trailer: 1974 Boler and 1988 Bigfoot
So the tires that are on your trailer are not trailer tires. I wouldn't venture off to far with them as you probably know rv tires are made differently Good Luck.
10-14-2019, 12:53 PM
yep.....
[QUOTE I wouldn't venture off to far with them as you probably know rv tires are made differently Good Luck.[/QUOTE]
sure.....trailer tires last half as long and when you have a flat with them they explode and disintegrate into pieces
