towing 1973 Trillium with bellybands removed? - Fiberglass RV
Old 04-21-2021, 12:49 PM   #1
Trailer: Trillium
Hi! I own a 1973 Trillium 1300 and was having some bodywork done to it by an older guy.....we have removed all of the belly bands. Unfortunately, due to health reasons, he cannot finish the job including fibreglass work/painting. So my question is:
1/ can i tow the Trillium about 10 kms to a new body/paint guy WITHOUT putting the bellybands back on OR will the upper/lower body shells fall apart?
Thanks for any help and enjoy your trailering!
JuliusB is offline   Reply With Quote
Old 04-21-2021, 12:58 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
No problem. They won't fall apart. Keep in mind that the belly band that was removed was just decoration. It did not hold the top to the bottom. A resin soaked fiberglass strip behind the seam (installed when built) holds the top to the bottom.
Only thing to be concerned about is possibly some water getting in, so you might want to tarp the trailer or put it inside.
Old 04-24-2021, 04:48 PM   #3
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Trillium Belly Band End Trim?
Hello,
I took the belly band off and am reistalling it.
Unfortunately, one the the end trim pieces of the belly band
is missing. I wonder if you saved yours and if I might buy
one or two from you?
Thank You,
Uncle Larry
Payson, AZ.
Larry C Hanson is offline   Reply With Quote
trillium
cleaning and polishing bellybands JuliusB Care and Feeding of Molded Fiberglass Trailers 13 12-12-2020 08:21 AM
QUESTIONS on Trillium Ensolite removed. x2uol Problem Solving | Owners Helping Owners 10 05-15-2013 09:25 AM
Just removed our old heater Kate Carney Problem Solving | Owners Helping Owners 20 08-07-2007 09:55 PM
