There's a hole in my Boler my Boler my Boler - Page 12 - Fiberglass RV
Old 03-08-2018, 10:46 AM   #221
Missouri
val I have spoken for fred first in mo. you will have to wait!!
bob
Old 03-08-2018, 04:50 PM   #222
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Originally Posted by FRED SMAILES View Post
Led lights for the exterior! Other people need to be able to see my intentions to changes lanes, apply brakes etc. The taillights work great at nite but not strong enough during the day.
Fred
I thought exactly the same thing about the original taillights. I even tried led bulbs but they were not any better. I ended up buying these and they are great:
https://www.etrailer.com/Trailer-Lig.../STL190RB.html
ststefan is offline   Reply With Quote
Old 03-08-2018, 11:42 PM   #223
FRED SMAILES's Avatar
Trailer: 13 ft Boler
hey Steve, yes I have looked at those units,, but to me they look so big.
Plus I spent a bit of coin on having trim rings made for the original lenses as shown in this old pic (2004) before I put the decal on.
What I hope to do is find a smaller unit that fits in the lens.
Fred
Old 03-09-2018, 12:18 AM   #224
ststefan's Avatar
Maple Ridge, B.C.
Fred
That one has the same footprint as the original taillights. They do have a 4" version as well. Otherwise I would probably add 4 sockets inside the lens ( one centered and 3 surrounding it). The center one would be your running light and the 3 surrounding one's would be the brake and signal. Of course you would be using 1156 style bulbs then and not 1157.
Old 03-09-2018, 06:19 PM   #225
My order of window operators showed up today,, THANKS IAN!!
I got thinking about the taillights and decided to pull off a lens and head down to the local truck shop. The fellows fixed me up in no time!
The light has 22 leds and is a little over 4 inches in dia.
The black donut is the panel installation gasket that just so happens to secure it perfectly in the original lens. So all that's required is to remove the 1157 bulb mount put a hole through the rear for the electrical plug, wire in the new
light and done.
When we got home from SoCal I just backed the trailer into a snow bank out of the way so the install wont be right away.
Fred
Old 03-09-2018, 07:00 PM   #226
ststefan's Avatar
Maple Ridge, B.C.
Nice! Looks like a perfect fit and a lot better than the original 1157.
Old 03-18-2018, 12:03 PM   #227
To follow up on my LED taillight install.
Went very smooth and happy with results.
First pic is 1157s brake and taillight both on,, pretty dismal.
In the second pic I just wiggled off the 1157 mount and cut the wires.
In the third pic I needed to create a hole for the plug housing on the back of the LED. My weapon of choice was a die grinder with a carbide tip.
Last pic is LED brake and taillight both on.
Yes the light would be brighter without the original lens covering it but it's way better than it was and is way brighter than the pic shows.
Old 03-18-2018, 01:58 PM   #228
The Harbor Freight round lights fit right inside of the original Scamp top hat tail lights and I glued them in with a bead of RTV.
Over the license plate I installed some white LEDs inside the clear window .
Brighter than the original and cheap too.
Appealed to my cheap side.
Old 03-19-2018, 02:09 PM   #229
Missouri
fred we cannot find decent grapefruits in mo! Is there a shortage?
bob
Old 03-19-2018, 03:52 PM   #230
ststefan's Avatar
Maple Ridge, B.C.
bob
Try a big rig supply store in your area.
Old 03-19-2018, 04:03 PM   #231
bob
Old 06-17-2018, 04:34 PM   #232
On Wednesday we're headed to Penticton for the Beach Cruise. It's an annual car show there with 800 or so entries parked along the beach.
Took the boler out for a scoot with the Comet aas a bit of a shakedown for the car. Travelled a ways up the Creston/Salmo pass and everything stayed together so looking forward to heading out.
Also, see that some of the pics I posted via Postimage have disappeared and since I can't edit those posts I'll post them again with a reference to a post number.
Old 11-01-2018, 07:40 AM   #233
Photo repairs lost from PostImage
Originally post 195
Changed out the stock jack because it was mounted on the side of the frame rail and that wouldn't work with cover I'm putting on the tongue. I had to mod this one because it was too low and wanted to be able to put a wheel under it.
In the pic you can also see the aluminum angle that is mounted to the bottom of the rail, this is for the cover to rest in.
Click image to inlarge
post 198
Well found a small crack on the drivers side frame rail on the bend at the front of the cabin so I plated the bottom and inside of rail at the crack.
Also reinforced under the door opening by adding a piece of channel iron under the door and tubing up from it at longer angles. I forgot to take before pics but the door hardly moves in the opening regardless if it's on it's wheels or jacks.
Everything down there is covered in fresh black Tremclad paint now!
Fred
Old 11-01-2018, 07:53 AM   #234
Continuing PostImage photos
Post 201
Got some paint on it the other day. Happy I decided to do do two coats of paint instead of primer and paint cause the hibernating flies came out and made a mess of the roof plus I had a few runs etc. Most of this will be sanded off but looks pretty shiney, sorrybbout the last pic.
Old 11-01-2018, 07:59 AM   #235
Post 203
Very happy with the way the cover turned out, Dave steal away! I've been accused of the same thing and this idea probably isn't entirely mine anyway!!
As for the marine paint job, for the 250 or so dollars I have in it, it is great!
No isn't as good as a spray but auto paint and material would be a G note plus more labour.
Old 11-01-2018, 08:01 AM   #236
Post 211
Her is the other pic I wanted to post but the WiFi at our park could be better.
[urlSS=https://postimages.cc/][/url]
I think this is all the photos that were lost when Photoimage went from org to CC.
I cant edit posts that have been replied to so this was the only way I knew to replace them.
Fred
Old 11-01-2018, 11:59 AM   #237
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Oldest continuous thread EVER?
Nothing useful to add, just wanted to say I'm loving the fact that this thread started in 2012 and it's still going on six years later. Long time to spend fixing a "hole in your Boler"
Old 11-01-2018, 05:14 PM   #238
Ya it's been a while,, I actually started on it the fall of '03.
Old 03-27-2020, 05:42 PM   #239
Trailer: boler
Amazing, just read through the whole thread again. I wanted an outside baggage hatch, you can get them on Amazon, but hubby says he does not want to cut into the exterior fiberglass, so will be using your drawer idea. I want to keep the bed down full time, so thought of using a bed lift just have to figure out how to mount it as I want to keep the original table underneath. Was originally going to take out the potty centre front, and put in a small dinette, but due to major health issues last year have decided we need to keep it, now to devise a plan, ideas stilll floating around my mind to make a table(s) that we can use sitting on the front couch.
Thank you for sharing your down to earth mods in an easy to understand way. Your unit is awesome with the Comet. We will use a 51 Chevy pickup as our tow vehicle.
Old 04-23-2020, 07:54 AM   #240
Trailer: 1975 Boler
Thanks! I am feeling pretty lost all around lol. It looks like you are going to be a great source for me Prepare yourself for a lot of stupid questions lol
Have a great day!
April
AprilDawn is offline   Reply With Quote
boler
BIG HOLE IN ROOF ( Boler ) trailerlust Problem Solving | Owners Helping Owners 17 04-07-2013 07:54 PM
BC Boler 13' Priest Referrals: Molded Fiberglass Trailers 1 03-14-2013 07:51 PM
17ft Boler 1980 needs a true Boler lover Tina Problem Solving | Owners Helping Owners 5 12-27-2010 10:48 AM
MY 2008 BOLER BLOG, Camping trips using THE TANK: 74 Boler 1300...Pics Jayson Wall Camping, Campout Reports 1 01-18-2009 11:49 PM
» Trailer Showcase
AbelEgg
TWelch
Casita
Ed F
