Boler door hinge - Fiberglass RV
Old 08-21-2018, 10:12 AM   #1
Boler door hinge
My Boler door is in good shape, as is the frame to which it is mounted. However, the door sits just a wee bit crooked, due hinge misalignment. Each hinge, as you all know, is secured with two screws per hinge. The top hinge, and the top screw on the bottom hinge I have been able to loosen with the application of heat on the screw. And, this allows the door to be adjusted to sit squarely, but with a larger gap on one side than the other.
However, the bottom screw on the bottom hinge sits in a very awkward position. I have tried everything I know of but cannot apply enough force to loosen the screw - and, I am afraid of destroying the hole for the screwdriver.
Any thoughts on how to get at this offending screw? The only thing I can think of is to drill it out. Thanks for your comments.
skyaki is offline   Reply With Quote
Old 08-21-2018, 09:48 PM   #2
Markz's Avatar
Do you have pictures of how the door presently sits? How crooked is it?
Old 08-21-2018, 09:49 PM   #3
Markz's Avatar
Have you tried break free?
Old 08-22-2018, 05:50 AM   #4
I have tried all manner of releasing agents, and have applied heat. The problem is access to the head of the screw - it is buried in the top corner of the settee. I have found no way to get in there to apply any meaningful torque to this troublesome screw. Right now - top gap 1/4", bottom gap 5/8".
Old 08-22-2018, 10:18 AM   #5
daveandbonscott's Avatar
Name: Dave and Bonnie
Boler door hinge
You can replace the screws and the washer (brass) easy for $22 from Ian Giles at Camping Treasures.com
so take the trailer to a tool and die company or an RV repair shop and have them
drill it out for you
that way you'll have nothing wrecked and a new hinge operation - note that the
metal hinges never wear out !!
best of luck
Dave and Bon with Berniece from New West BC
daveandbonscott is offline   Reply With Quote
boler
Door hinge repair kit for Boler or Trail Mite KenandJaney Problem Solving | Owners Helping Owners 2 07-16-2012 09:56 PM
The subtle mysteries of the Boler Door hinge sara maccalman Problem Solving | Owners Helping Owners 21 09-01-2011 04:50 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
boler door hinge pins Ben, Vanden Berg Problem Solving | Owners Helping Owners 9 07-23-2009 12:25 PM
