I replaced the seal with a D shaped seal that I stuck around the inside of the door frame, i.e so that the door would close 100% over the seal. That made things a little tight and the door needed a solid slam to close.
But I"m not happy with it and have been told that
Scamp sells a rib door seal that is supposed to be really good.
https://www.scamptrailers.com/parts-...al-detail.html
My question is, where do I place the seal? It says with the rib facing out, so...
1. Do I / can I stick it to the door (the very edge of the door) with the rib pointing out and have the door+seal close against the frame; or
2. Do I stick it to the door opening itself so that the door closes against the frame+seal. And would I position it on the inner or outer part of the door opening frame? See picture, and forgive the artistry.
and of course, the seal would go all the way around.
