windows boler trailer - Fiberglass RV
Old 06-26-2019, 05:06 PM   #1
Trailer: boler
nb
Hi, I'm looking at replacing side windows on my trailer. I'm knew to this and don't want to remove the windows until i am ready. Is the wall thickness uniform around the trailer as it seems to be between 1/2 to 3/4 ''. i have a Boler 13' made 10/74. Any help would be appreciated. Thanks.
garyr is offline   Reply With Quote
Old 06-26-2019, 10:09 PM   #2
David B.'s Avatar
Gary, the wall thickness is pretty uniform as you have suspected. The thickness of the fiberglass is much less, but by the time you add in the insulation, wall covering, and perhaps wood backing for the windows, you would be looking at 1/2” to 3/4”. Do you already have windows to replace your current ones, or are you simply removing them to re-glaze your existing frames? Butyl putty tape is the best to reseal the frames to the fiberglass shell when you replace them. Best of luck.
Dave & Paula
boler, windows
To pull out my windows or not pull out my windows??? Alyson Brown Care and Feeding of Molded Fiberglass Trailers 15 04-30-2017 07:24 AM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
