Boler Floor Repair - Fiberglass RV
Old 04-21-2020, 12:48 PM   #1
Trailer: 1974 Boler 1300
Question Boler Floor Repair
I just pulled out the laminate floor that the previous owner had put in my '73 Boler and found several issues.
1. The flooring had been shimmed using small pieces of plywood to level it out.
2. There is fiberglass with what appears to be gel coat over the plywood subfloor that has a hole in it.
3. The floor is really soft and spongy.
I am wondering if I should cut out the fiberglass top layer, replace the plywood underneath and coat with new fiberglass top and bottom? Or as another option put the original fiberglass layer back down and fix the hole that is in it.
An help would be greatly appreciated.
[ATTACH]Click image for larger version
Seattle Boler is offline   Reply With Quote
Old 04-22-2020, 10:14 AM   #2
Trailer: boler
I took the entire floor out of my 72, was really easy and I think worth it, use it to make a new template with treated plywood, and after installing it cover with vinyl planking
artichoke is offline   Reply With Quote
Old 04-22-2020, 10:23 AM   #3
So you took out the fiberglass and the plywood underneath?
Old 04-22-2020, 01:26 PM   #4
Trailer: boler
floor repair
In mine after removing the original ugly yellow lino flooring the plywood was riveted to the frame , ground off the rivets, lifted out the plywood. cut new flooring and replaced it
boler
Question – fiberglass repair– gap between wood-floor and “wall” of ori lenny247 Problem Solving | Owners Helping Owners 13 04-06-2022 10:49 AM
boler floor repair underside Tenneille M. Problem Solving | Owners Helping Owners 3 05-28-2019 11:56 AM
Fiberglass/plywood floor repair questions ... freddo411 Modifications, Alterations and Updates 6 12-11-2011 09:45 AM
Floor repair on '83 Scamp DennisM Problem Solving | Owners Helping Owners 6 05-30-2010 06:35 AM
Floor Repair Keith alholm Problem Solving | Owners Helping Owners 2 02-22-2008 03:34 PM
