Boler tongue replacement - Fiberglass RV
Old 05-30-2020, 06:43 PM   #1
daveandbonscott's Avatar
Name: Dave and Bonnie
I have a 77 Boler and my hitch tongue is worn out enough that it may not be all that safe. I want to replace it. Anyone who can help with sourcing the tongue replacement and removing/replacing steps I would appreciate it. I am in New Westminster BC Canada.
Dave and "Bernice"
daveandbonscott is offline   Reply With Quote
Old 05-30-2020, 11:51 PM   #2
Trailer: Trails West
do a websearch with the keywords below. You will need to match what parts you get with the style of coupler you have. There are video tutorials on youtube for doing this task.
"coupler repair kit"
Old 05-31-2020, 06:46 AM   #3
Clean it up and take a good look at how it is made. There are slots on the side that the hoop in the front pulls the lock forward to lock the system in place. The top latch holds the hoop in place. Also there is a hole just behind the hoop for a pin that will lock the hitch so that it cannot open up either to hitch up or come off.
Close the hitch and jack up the front to see if you can raise the TV/hitch to make sure it is solid.
If I were to replace that hitch I would look for a Bulldog that matched the angle of the trailer frame.
To feel more comfortable I often wrap a small bungee cord over the latch on top, but best is that safety pin through the hole.
Old 05-31-2020, 08:57 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
A nut in the bottom of the coupler can be turned to adjust the tightness of the coupler.
Old 05-31-2020, 10:21 AM   #5
thank you all three of you for your input. redbarron55 you describe my tonque operation exactly. I will do the search, k corbin. And now I can be sure it's on tight, John
So appreciative of this site and the "insight" others have
Dave and "Bernice"
boler
Replacement Tongue Jack for Scamp 13 Deluxe 2016 sal6342 Towing, Hitching, Axles and Running Gear 18 07-01-2018 10:19 PM
Bigfoot 19 Tongue Cover Replacement Jane P. Towing, Hitching, Axles and Running Gear 24 07-17-2011 03:48 PM
Tongue Jack Replacement? Parker Buckley Problem Solving | Owners Helping Owners 8 12-03-2007 09:06 PM
Boler 17 tongue weight Dwight Burditt General Chat 2 02-19-2007 07:57 PM
Boler tongue jack replacing? Legacy Posts Problem Solving | Owners Helping Owners 13 07-18-2003 04:41 PM
