Catalytic or Buddy portable indoor propane heater for Scamp 13 - Page 4 - Fiberglass RV
Old 01-11-2020, 05:22 PM   #61
Trailer: Escape 19
Newfoundland
I use a small circulating oil heater and it works well to keep my 19foot trailer warm at moderately cold temperatures (for Canada that is) The best thing about it is that it's completely silent.
Barb Hunt is offline   Reply With Quote
Old 01-11-2020, 05:36 PM   #62
Originally Posted by Len S View Post
A trailer as small as this ; I would not use any internal heater such as this. Yes some recommend leaving vents open , such as overhead and or side windows so now this becomes self defeating....
Not really self-defeating at all. Usually, a Wave heater, with windows and roof vent in the camper open as required, will still keep the camper plenty warm and perhaps too warm, and do so while using much less propane than a vented furnace. You really dont lose that much more heat with the vent / window cracked vs having them closed, especially in these generally leaky campers.
The much higher efficiency of the Wave more than makes up for the open vent / window.
What is really self-defeating, from purely an efficiency point of view, is to dump as much as half the heat produced to the outside of the camper. Hold you hand up to the vented furnace vent when its running and its clear how inefficient the furnace is.
Still, as I have said, the inefficient vented furnace is only one I would consider using while sleeping.
Old 01-11-2020, 06:04 PM   #63
DJD
Louisiana
I’m with Steve
I have used a Big Buddy to raise the temp in my workshop and I do no like the fumes! I did not think it would smell, but I was mistaken. I will use it again when temps are below 35F, but I will turn it off when I enter after raising the temp a little. I am not familiar w. The catalytic.
DJD is offline   Reply With Quote
Old 01-11-2020, 06:36 PM   #64
Byron Kinnaman's Avatar
Originally Posted by steve dunham View Post
Just a question / observation ; If it’s so COLD in the shower room that you need to drag along a portable propane heater wouldn’t the water in the shower freeze ?
Not really. Cold is different for everybody. I've seen people put on wool lined coats at 70°F And people going shirt less at 40°F neither one near freezing.
Old 01-11-2020, 06:48 PM   #65
nefldiver's Avatar
Name: ROY AND BETH
Trailer: BIGFOOT 21 FB
My Bigfoot furnace is very efficient. And my trailer is very airtight and we'll insulated. Rated to minus 20 and up to 120 F.
nefldiver is offline   Reply With Quote
Old 01-11-2020, 06:50 PM   #66
nefldiver's Avatar
Name: ROY AND BETH
But yes a lot of the heat is wasted
Old 01-11-2020, 07:37 PM   #67
Originally Posted by nefldiver View Post
My Bigfoot furnace is very efficient. ...
Those two statements are incongruent.
Efficiency is the ratio of heat output (to the living space) of the furnace compared to the total fossil fuel energy consumed by said furnace. A vented furnace might be effective at keeping the interior of the camper warm but that is not the same as efficiency. The point was that, using a Wave catalytic heater, I could keep my camper warm for a much longer time on the same amount of propane as I could using a vented furnace. So could you.
That does not always make the Wave the better choice however. A vented furnace has many advantages over a non-vented catalytic heater, despite the large difference in efficiency.
On the other hand, if you have no electric power available (battery or shore power), then the furnace will not even run. In that isolated case, the Wave is clearly the better option (unless you don't follow the directions to vent!).
Old 01-11-2020, 07:57 PM   #68
nefldiver's Avatar
Name: ROY AND BETH
1-800-COOLING
When You Need A Company You Can Trust.
We’re Here To Help
Resources Careers Offers Financing Blog Customer Reviews Hvac Glossary I Have Questions... What You Should Know About Energy Efficiency Facts About Carbon Monoxide Poisoning Privacy Policy
Resources / Facts About Carbon Monoxide Poisoning
FACTS ABOUT CARBON MONOXIDE POISONING
Carbon monoxide is the leading cause of accidental poisoning in the United States today.
Carbon monoxide (CO) poisoning can happen within a matter of minutes and is responsible for more deaths than any other single poison. This odorless, colorless poison can hurt you slowly in low levels, cause permanent neurological dysfunctions in moderate levels, and take lives in higher levels.
Oil, propane, and natural gas fired heating systems, gas appliances and fireplaces all release carbon monoxide as they burn and can be health and fire hazards.
Old 01-11-2020, 07:58 PM   #69
nefldiver's Avatar
Name: ROY AND BETH
Old 01-11-2020, 08:17 PM   #70
And the point is? (and the point of the cut and paste double post is? )...
If the point is to always use a carbon monoxide alarm then.. DUH! We all agree.
If the point is to not use "Oil, propane, and natural gas fired heating systems, gas appliances and fireplaces".... then I have to suggest some reasonable risk assessment least we decide to stop towing our campers anywhere...
Over 37,000 people die in road crashes each year in the US
While at the same time...
Every year, at least 430 people die in the U.S. from accidental CO poisoning
(BTW, thats 1.1 percent CO vs MV deaths).. But risks are all around us, in varying degrees. Common sense is advised!
Old 01-11-2020, 08:57 PM   #71
nefldiver's Avatar
Name: ROY AND BETH
Ooh touchy are we?
Old 01-11-2020, 09:16 PM   #72
Ooh touchy are we?
Who are you asking?
I for one (among many perhaps) is / are just trying to understand what point you were trying to make. Saying that carbon monoxide is dangerous is like saying that fire can burn you. Was there more to your post than that?
Old 01-11-2020, 09:18 PM   #73
Glenn Baglo's Avatar
That's called false equivalence. Here you go, but you can look into if further yourself.
False equivalence is a logical fallacy in which two incompatible arguments appear to be logically equivalent when in fact they are not. This fallacy is categorized as a fallacy of inconsistency.[1]
Old 01-11-2020, 09:24 PM   #74
floyd's Avatar
So which should the caveman regret more... the discovery of fire , or the invention of the wheel?
Old 01-11-2020, 09:32 PM   #75
Trailer: boler
Originally Posted by zack sc View Post
so all you need to do for safe venting is open the roof vent by 1/4"?
is opening the roof vent better than opening a side window?
Thanks.
As others have said either open the vent and or crack open a window, mostly for moisture reasons. The Little Buddy Heater we have has an oxygen sensor, so if oxygen gets too low it shuts off. Never had an issue mostly used when tenting, still have it but, now have a 5th wheel and boler in renovation which have furnaces.
Old 01-11-2020, 11:18 PM   #76
nefldiver's Avatar
Name: ROY AND BETH
[. Saying that carbon monoxide is dangerous is like saying that fire can burn you. Was there more to your post than that?[/QUOTE]
You can see and feel and smell fire ... That's one of my main points!!
Old 01-11-2020, 11:22 PM   #77
nefldiver's Avatar
Name: ROY AND BETH
The main way you realize you've gassed yourself is waking up at the pearly gates. ( Am giving all the benefit of the doubt, after all most of us do own mft"s )!!
Old 01-11-2020, 11:31 PM   #78
Trailer: Trillium
I have used the "little buddy" on occasion in my Trill.
I usually crack the roof vent, and have the window on the door open a bit.
Also, the two side windows leak like sieves. Those alone are probably enough. lol.
I have never run it overnight. Like mentioned before, I have woken up, in the middle of the night cold, and run it for a bit. Usually a couple of times per night. And definitely in the morning!!!
When it is really cold, I have a metal 5 gallon container that I have cut the side out of. I will put a couple of big candles in there. Still make sure that there is some air available. Keeps everything above freezing, but not be much!!
I have scrounged a used forced air furnace (from an RV being wrecked) and plan on utilizing it some way or another.
Trill136 is offline   Reply With Quote
Old 01-12-2020, 12:30 AM   #79
It matters not what the source of combustion is. Candles, propane, diesel, white gas, fire logs. They all produce carbon monoxide.
Old 01-12-2020, 12:37 AM   #80
Everywhere
The current-gen furnaces aren't quite *that* bad in terms of efficiency. They're on the order of 70-75%, which is quite a bit better than the old 50% ones. Propex's furnaces are closer to 90%, and I think the Truma Varioheat's higher than that (though it's not in the US yet so far as I know). Still not as good as a home condensing furnace, but good enough that it's probably close to a wash in terms of heat lost to ventilation vs furnace inefficiency.
propane, scamp
Boler 1300 catalytic propane heater performance skryabin Problem Solving | Owners Helping Owners 8 09-18-2011 07:49 AM
Portable catalytic heater Paula Bindrich Problem Solving | Owners Helping Owners 19 10-13-2007 04:53 PM
Anybody Here Use a Mr Heater Portable Buddy? Buck62 Modifications, Alterations and Updates 17 01-18-2007 06:17 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
Mr Buddy Propane Heater Legacy Posts Modifications, Alterations and Updates 12 02-08-2003 07:27 AM
