04-03-2020, 12:30 PM
#21
Trailer: Casita - 2019 SD17
Idaho
Originally Posted by Casita Greg
. . . (who read all the Casita forums regularly,)
Currently, this is the only forum I am on. What are the other forums I should read? I am very new to FG and RVing, so I appreciate learning from the "Pros".
04-03-2020, 02:05 PM
#22
Trailer: Oliver
I have been using conductive grease on those 7 pins and so far so good. Also, I store mine inside the electric jack cover hanging down.
04-03-2020, 02:38 PM
#23
Idaho
I like the idea of an electric jack cover. Was that an after market addition? Did you make it yourself or did you buy it commercially? A jack cover would kill two birds with one stone.
04-03-2020, 03:49 PM
#24
These are links to the two Casita forums that are used the most. The first one is quite active, the second one is not as active.
And both of them require you to subscribe, i.e. "join." However, neither one of them requires any kind of payment or dues to be a member, but you must register on each site and be approved, (usually within a day or so.).
https://www.casitaforum.com/invboard/forums/
Casita Club - Casita Travel Trailer Owners and Prospective Owners
04-03-2020, 06:54 PM
#25
Trailer: '15 17' LD Casita and '17 Tahoe LT
04-03-2020, 07:59 PM
#26
Trailer: Oliver
Bob, I purchased the jack cover from Camping World. I spray it with 303 to get it to last a little longer which is about 2-3 years. It does stay dry under it though.
04-03-2020, 10:18 PM
#27
Idaho
Stainless Cable Ties
Originally Posted by dmad1
Thank you for the link. I did not know they made stainless cable ties. I will definitely check that out. I have been using a lot of pipe clamps.
04-06-2020, 08:04 PM
#28
Wisconsin
Hose clamp mounts
I like your solution. I find that almost all cable ties have a short life when exposed to UV light (the sun). Hose clamps sound like an excellent solution. I assume you used stainless steel clamps..
Here is the holder as mounted. I should have never tried to use plastic zip ties in January.
04-07-2020, 08:23 AM
#29
Idaho
Thank you Kenneth for the picture. The stainless steel clamps make for a very professional installation and look.
When something is going to be exposed to direct sun light, I always recommend use of stainless steel clamps or the equivalent over nylon cable ties, as the nylon ties have a very short life when exposed to strong UV light. They become brittle and break when any stress is applied to them.
04-07-2020, 08:39 AM
#30
NW Wisconsin
Nylon Cable Ties
[QUOTE=Bob Penn;773681 They become brittle and break when any stress is applied to them.[/QUOTE]
They also become extremely brittle in cold weather . I tried clinching up some black cable ties last week when temps were near zero F
After snapping about a half dozen I gave up .
04-07-2020, 09:18 AM
#31
I used the plastic ties that came with the plug protectors but keep them under the nylon and vinyl cover I bought to put over my electric tongue jack. I had to buy two of those plug protectors as my electric tongue jack has its own 7 pin plug to plug into the tow vehicle when hooking up or unhooking which means it doesn't have to be wired permanently to the trailer. I really like that feature. I did not know that there even was such a thing as Stainless Steel ties but will sure be picking up some on my next trip to Harbor Freight.
Lee
04-07-2020, 09:46 AM
#32
Wisconsin
Stainless clamps
Note that most of the stainless clamps now have non stainless screws. We used plastic pipe under ground on the farm 40 years ago and the clamps lasted, but todays screws rust into a ball of rust, only the band is stainless. To test, check to see if they are attracted to a magnet, if they are, they will rust. They are still better than zip ties. (Black zip ties last longer than white)
04-07-2020, 10:31 AM
#33
I was talking about stainless steel zip ties which have no screws and once installed can only be removed by cutting them just like a plastic zip tie. You must be thinking of hose clamps.
Lee
04-07-2020, 02:38 PM
#34
Wisconsin
Yes
I've never used them, because of my background I've always had two other types around.
04-08-2020, 06:25 PM
#35
I got took by the Casita Factory. I purchase what the title says is a 2020 model however it has none of those upgrades.
Jim Hoffman
20?? Casita Spirit
04-08-2020, 06:30 PM
#36
Jim Hoffman
20?? Casita Spirit
Take it back.......
Jim
Never in doubt, often wrong
04-09-2020, 05:29 AM
#37
Illinois
Those upgrades are for models being produced for Summer pickup if I remember correctly.
We just picked up our Casita (a 2020) as well and I had inquired about it.
04-09-2020, 03:27 PM
#38
Well then haw do you claim you are getting a 2020 model.
04-17-2020, 06:21 AM
#39
Illinois
Valid point.
04-17-2020, 07:17 AM
#40
2020 Casita Upgrades and Modifications
Manufacturers are under no obligation to make changes only at the start of a new model year. I could name many major changes at Scamp that happened in mid-year. I don’t follow Casita as closely.
If what you got was what was offered/shown at the time you ordered, then you really can’t complain. Even if not, I’m pretty sure every sales brochure and contract have in the fine print, “specifications subject to change without notice.”
I can certainly understand feelings of disappointment when you find out you just missed a desirable upgrade. However, it can work the other way, too...
There were some unhappy Scamp customers when Eveland’s made an unannounced decision to eliminate the small window in front bath models in favor of a powered vent. People who ordered when the window was standard went to pick up their trailers and... surprise!... no window. An e-mail with an explanation of the reason for the change in advance of delivery might have prevented some hard feelings.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
FL | 2020, Feb 10-15: ScampCamp 2020
floyd |
Rallies, Get-togethers, Molded Meets (Archive) |
29 |
09-05-2021 12:21 PM |
NH | 2020, May 14-17: Spring Fling in New England for 2020
Gerry |
207 |
09-09-2020 05:39 PM |
IL | 2020, June 5-7: 4 B’s 2020
The Menace |
39 |
06-13-2020 06:12 PM |
WA | 2020, May 15-17: Maryhill in May 2020
paulw |
56 |
05-10-2020 10:45 PM |
BC | 2020, June 5-7: Vancouver Island Bolers and Friends June 2020 Meet-up
Island Claire |
0 |
10-21-2019 12:19 PM |
