Furnace Install for 77 Boler - Fiberglass RV
Old 05-12-2020, 11:09 AM   #1
Newfoundland
Hello,
I would like to install a propane furnace in my Boler but I am not sure if it will fit properly. The opening that I am considering is under the sink, over the wheel. The dimensions of the opening: Depth: 18 3/4 " ; Height and width: 12 1/2 "
A couple of furnaces that I have seen online have a cut out depth opening requirement of 20 inches deep and 21 inches deep. Does anyone have an opinion on using one of these furnace in the opening I have described?
Although the recommended cut out opening does not meet the manufacturers' specs, would it work if there was either a slight protrusion outside the surface of the cabinet? Other options or suggestions?
Clyde
Clyde is offline   Reply With Quote
Old 10-28-2020, 07:27 PM   #2
Jan Dyke's Avatar
Trailer: boler
Hi Clyde. It sounds like I put a similar furnace in my 73 boler same location. I used some 1 1/2 ×1 inch molding around the opening to get clearance to the outside wall
Jan
Jan Dyke is offline   Reply With Quote
Old 10-29-2020, 11:25 PM   #3
David B.'s Avatar
Try looking at a Propex furnace. If you click on my avatar then on my photo albums, you’ll see how small they are.
Best of luck.
Dave and Paula
Old 10-30-2020, 10:15 AM   #4
Jan Dyke's Avatar
Trailer: boler
David they are nice but I can't justify spending that kind of money for only a few times using it per year. It really never gets that cold here in the PNW. I personally would install a Diesel heater if I was going to upgrade
Old 10-31-2020, 07:02 AM   #5
TN
It wouldn't hurt the furnace but I bet you will wack you knee or shin on that sucker. I put a Chinese diesel heater in my Boler primarily because of the foot print and I like it so far. Haven't really put it to the test yet. Biggest issue is figuring out were you can mount the fuel tank.
Eric Frye is offline   Reply With Quote
Old 10-31-2020, 10:14 AM   #6
Jan Dyke's Avatar
Trailer: boler
Eric. I watched an install of the diesel heater. He mounted it under the front bunk but for the fuel tank he just set a Jerry can beside the front of the trailer and put the fuel pickup in that. It worked well for him and didn't have t worry about stinky diesel inside his trailer
Old 10-31-2020, 05:16 PM   #7
Trailer: Trails West
If you are getting diesel stink inside your trailer you have not done the installation properly. You need to connect a vent line from the fuel tank, if you have it mounted inside, to a thru wall fitting. Any diesel fumes from the ignited burner will be exiting through the exhaust line fitting that goes to the exterior.
When installed correctly there is no smell of diesel inside the trailer.
Old 10-31-2020, 09:44 PM   #8
Jan Dyke's Avatar
Trailer: boler
There was no mention of fumes from it burning. I watched a couple of videos of guys filling up the tank that was situated inside their trailer. 1 bit of a spill and that would stink.
Old 11-01-2020, 07:03 AM   #9
TN
I mounted my tank on the back outside wall of the trailer to avoid any fume issues. Right now it looks a little unsightly but I will eventually have an a/c unit and a tankless hot water unit mounted back there. I will put a cover over all of them to pretty it up and provide protection from the elements. [IMG]Running Lights by Eric Frye, on Flickr[/IMG]
Old 11-01-2020, 10:16 AM   #10
Jan Dyke's Avatar
Trailer: boler
I like it great idea
boler, furnace
origional furnace install - boler 13 - curious it is. glamourpets Care and Feeding of Molded Fiberglass Trailers 6 04-21-2013 07:16 PM
Furnace install rgrugg Modifications, Alterations and Updates 9 03-13-2013 06:43 AM
Furnace install rgrugg Modifications, Alterations and Updates 23 03-11-2013 03:50 PM
Furnace Install Mike Hannigan Modifications, Alterations and Updates 5 06-07-2010 07:54 PM
Trillium Furnace Install Tracy S. Problem Solving | Owners Helping Owners 3 08-05-2009 10:06 AM
