Okay so I have been planning out the modification of our Casita 16 shell. The frame is shot so since it needs a new frame anyway I have decided to lengthen the
fiberglass trailer body from 13' to 17' or 18', widen it from 6'6" to 8' and add 1' of interior height. So the frame will extend to 21' tongue to bumper and widen to support the extra width. I was initially planning to do the frame myself due to possible modifications to the frame as the project moves forward but I have decided to let my friend Robert a professional welder build it for me. For 2 reasons one is I don't have full confidence in my welding/fabricating to pull it off without having to pull him into it for assistance anyway should I run into problems and two while he is building the frame I can be progressing simultaneously on the
fiberglass body work to speed up the project.
So here are the numbers for the new frame (keep in mind this is larger than a standard Casita 16 or 17 frame):
Prices includes coupler, tongue jack, chains,
axle with
brakes, all materials and labor. Everything except the wheels and
tires.
Metal frame $2975 with estimated weight of 700 lbs not including the
axle weight. A36 structural steel tubing construction.
Aluminum frame $3897 with estimated weight of 350 lbs not including the
axle weight. 6061 T6 Aluminum.
Prices are based on today's metal prices and could go up as inflation increase.
My goal is to keep the total dry weight to under 3500 lbs so I have 2800 lbs to play with going with steel vs 3150 with aluminum. My goal of 3500 lbs is not critical but a goal. It will be towed with a full size GMC truck or a heavy SUV most likely a Tahoe so if it goes over 3500 lbs is not a huge concern I am just looking at fuel economy with relation to the weight as well as tongue weight concerns.
Either way I decide to go I will be carefully looking at the weight of the interior build out as well as water weight in the freshwater tanks. Gray tank will be same size as freshwater, black will be a separate tank probably around 10-15 gallons. I will also be
weighing the things we take now such as tables, chairs, cooler, bikes, yaks, etc etc to accomodate for a total estimated towing weight for specking out the torsion axle. If your wondering I am going about this as if we will be full timing in this unit, but as for now we are just planning some extended trips across the country.
The cost is quite a bit more than I was expecting but I trust my friend will do a great job on this frame so I will have piece of mind towing across the country.
I will let you all know which one I go with after I get some estimated total weight calculations of the build, water in tanks and our stuff.
