HI Im new and just bought a 88 Casita 13' - Fiberglass RV
Old 10-08-2021, 10:52 AM   #1
Trailer: 1988 Casita 13' Deluxe
West Virginia and Texas
Hello
I am excited to be a new owner of a 1988 Casita Deluxe 13'. It needs TLC and Im trying not to be discouraged. I am new to Casitas but been a long time Rver, full time for over 12 years but now have a stick house and some land.
So currently I know the floor needs replacing, its not terrible and it is road worthy but needs to be done eventually. So far I was told everything works but I have not checked yet. soon.
The finish is my biggest current concern, I think its dull and looks painted. When I touch the surface it feels like orange peel. So I am really trying not to be totally bummed out about what it would take to ever get it shiny again and does that even really matter in the end? Im getting under to look at frame today.
High Glass is offline   Reply With Quote
Old 10-08-2021, 12:17 PM   #2
Jon in AZ's Avatar
For very old and very weathered gelcoat, people seem to be getting the best results with Zep high gloss floor wax. Depending on climate and storage people are getting 1-2 years between applications, possibly more if you have indoor storage.
There are numerous old threads on the prep, application, and removal process. be sure to use the "site search/google" option at the bottom of the search menu for best results.
Before applying the first time you have to get the trailer really clean and remove all the chalky oxidized gelcoat. I would wash with Dawn soap, then Barkeepers Friend to remove the oxidation, then a final wash with clean water. When dry, wipe on multiple thin coats of the floor wax with a white cloth. For re-application, you will need to use the Zep stripper.
The first time might be a long day's work on a small trailer, but reapplication is easier.
Good call on the frame. Frame failures are common on older Casitas, and typically happen under the front of the cabin where the frame transitions to the tongue. Wouldn't hurt to have a professional welder have a look.
Old 10-08-2021, 04:35 PM   #3
My husband is convinced its been painted with a roller? I have to determine what has been done to it
Old 10-08-2021, 07:56 PM   #4
FRED SMAILES's Avatar
Trailer: 13 ft Boler
If it was painted with a roller it's probably a latex or lacquer paint.
Rubbing it with gas line antifreeze, methyl hidrate will remore latex.
Rubbing it with acetone will remove lacquer.
Gelcoat or good quality 2 part paint won't be affected.
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
Old 10-11-2021, 04:11 PM   #5
Hello, I have determined it was painted. I am a little bummed about it.
casita
Hello and we just bought a 1973 Trillium kimnmiller Hi, I am.... 14 10-03-2020 02:10 PM
Just Bought Casita 17 Standard in Las Vegas deshet Hi, I am.... 24 01-03-2019 09:35 AM
Just bought used and need maintenance/restoration suggestions AdventureAuthority Care and Feeding of Molded Fiberglass Trailers 8 07-04-2015 08:49 PM
Just took the plunge and bought a DannyH General Chat 7 05-19-2009 09:30 PM
New to Trailering...Just bought '82 Burro Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 08-15-2003 10:22 AM
