Axle Specification for 77 Beachcomber - Fiberglass RV
Old 12-04-2020, 06:50 PM   #1
Trailer: 77 Beachcomber
Hilton Beach
My axle is bent toward the rear by about 5/8 inch. I have no idea if it is the original axle. I want to shop for a replacement but i cannot find the specifications for the original axle. Can anyone help me out on this?
The Cac is offline   Reply With Quote
Old 12-05-2020, 10:47 AM   #2
Trailer: currently shopping
axle specs
Can't help you with the original specs but, one approach might be to get it unloaded, take it to a scale & get it weighed. Then add 1500 or so lbs to that (cargo or carrying capacity), and then look for a slightly higher rated axle.
It looks like many manufacturers today use axles that are rated near the gross weights of their trailers or even slightly below that. I think if the axle weight rating is too high, you'll bounce over every bump.
DaveMinBako is offline   Reply With Quote
Old 12-08-2020, 10:30 PM   #3
Hilton Beach
Problem Solved
I was able to determine that the bent axle was of a 3500# configuration based on the diameters of the spindles and bearings.
In choosing a new axle, I considered the physical characteristics of my RV. It will weigh approx 1600 lb dry once I finish rebuilding it. I allowed another 300 lb for gear and provisions for a total of 1900 lb and rounded up to 2000 for good measure. The engineering people at Flexiride suggested a 25% factor of safety to allow for occasional impact loading due to road bumps and potholes. Therefore I needed an axle with a 2500# load rating.
New 3500# torsion axles, available from either Flexiride or Dexter can be derated by up to 30% at the time of manufacture by reducing the length of the rubber cartridges before they are pressed into the axle tube. So my new axle will be dimensionally identical to a 3500# axle but will be rated at 2500#.
Old 12-09-2020, 07:18 AM   #4
One thing about original specifications is that assumes the original specs were correct. Some of these older trailers were under built in regards to axle and frame. So copying the original spec could be unwise. Instead, get what is appropriate for your trailer. Advice above is good, weigh your trailer at a certified scale and add a reasonable safety factor.
axle, beachcomber
1978 Trillium axle specification Steve DeWeese Problem Solving | Owners Helping Owners 5 06-19-2014 11:02 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
