1986 13’ Perris Pacer axel - Fiberglass RV
Old 06-28-2022, 05:34 PM   #1
Trailer: 1986 Perris Pacer
West Virginia
I need to replace the original axel on our 1986 PP. Does anyone know if it’s the same axel as the older scamp 13’ . I called scamp and they won’t confirm or deny that the replacement axel they sell would work. I’ve looked for several hours on here and can’t find any posts saying it would fit as it should.
Any help would be appreciated.
Duane
Duane Boyce is offline   Reply With Quote
Old 06-28-2022, 06:41 PM   #2
Dan Meyer's Avatar
Trailer: 2000 Scamp 16 ft Side Dinette
I would go right to the manufacturer; Dexter axle. I would suggest reading the applications manual and figure out which axle fits your application. This will involve getting under your trailer and taking a few measurements. In addition you need to know the gross weight of your trailer. https://www.dexteraxle.com/user_area...it-008-00).pdf
Good Luck, and keep us posted.
--Dan Meyer
Dan Meyer is offline   Reply With Quote
Old 06-29-2022, 07:44 AM   #3
Jon in AZ's Avatar
Scamp has no way of knowing the exact design and measurements of a Perris Pacer frame. There are a lot of frame variations among the Boler clones.
You can work directly with an axle seller, in which case you will be responsible for taking all the required measurements on the order form. Mistakes are costly. Or you can work with an installer, in which case they will take the measurements and bear the resonsibility for any errors. If you use an installer, shops that do a lot of work with cargo and utility trailers are a better bet than RV shops. You want someone that does a lot of axle and suspension work every day.
Old 06-29-2022, 12:38 PM   #4
Duane
An "AXEL" is a jump in figure skating.
Your trailer, and all vehicles have AXLES
Old 07-01-2022, 10:59 PM   #5
CharlesinGA's Avatar
Georgia
This company is a Dexter Parts Distributor (but an independent company) Dexter Parts, Dexter Axles | Dexter Brakes | Dexter Parts | Torflex Axles and in their catalog, http://www.dexterpartsonline.com/fil...%20Section.pdf You will find all you need to know about the Dexter axles, options, how to measure, etc.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 07-11-2022, 05:34 PM   #6
West Virginia
Thanks for pointing out my spelling error, very helpful 👎🏻
As for the advice given by the others, thank you for the information.
perris pacer
74 perris pacer..axel problem or bearing? hangemhigh Problem Solving | Owners Helping Owners 12 03-08-2017 10:27 PM
Kansas Rally-Perry Lake Ricky 4 General Chat 7 07-02-2010 01:28 PM
Kansas Rally at Perry Lake - Rock Creek campground Ricky 4 Rallies, Get-togethers, Molded Meets (Archive) 53 06-11-2010 08:56 AM
