New freshwater tank for Trillium 4500 - Fiberglass RV
Old 02-04-2021, 08:30 PM   #1
Trailer: Trillium 4500 (1979)
Manitoba
Help, please! I'd like to replace the 41 year old freshwater tank on my 1979 Trillium. Ideally looking for a BPA-free, approx 12 gallon tank, with these dimensions: 27.5" x 18" x 5.5". The new tank could be up to six inches longer, and up to 1.5" wider - but *no* deeper. I've looked far and wide - anybody have a source for replacements?
SusanP is offline   Reply With Quote
Old 02-04-2021, 09:19 PM   #2
Trailer: Scamp 16 Std Layout 4
West Virginia
I've found a good selection of tankage at National Tank Outlet, ntotank.com. And also on Amazon! Both have fresh water, grey water, and even black water tanks in many different sizes. I'm replacing the 12 gal. fresh water (with a leak somewhere) in our Scamp with a 20 gal tank that's just a little bit longer, a couple inches wider and the same height and should fit in the same area. Good hunting.
Rod D is offline   Reply With Quote
Old 02-05-2021, 08:37 AM   #3
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
Which is the Width, Length and Height?
AlanKilian is offline   Reply With Quote
Old 02-05-2021, 09:11 AM   #4
Manitoba
The Trillium 4500 original tank is 27.5" long by 18" wide, and has a depth of 5.5". I can add up to six inches in length (to about 33.5"), about 1-2" to wideth (to about 19-20" wide), but the depth of 5.5" is fixed and firm, given the floor. I'm in Canada (the middle!), but am happy to pay for shipping anywhere in North America. Really hoping for some solid leads from current owners - I went down the Amazon rabbit hole without any success!
Old 02-05-2021, 09:20 AM   #5
Massachusetts
"33.5 long by 19-20" wide by 5.5" deep MAX"
You can go here: https://www.ntotank.com/rv-fresh-water-tanks
and click on "Height" to sort by height.
This is as close as I've seen to your dimensions. A 10-gallon tank:
32" Length x 19 1/2" Width x 4 3/4" Height
https://www.ntotank.com/10gallon-ron...-tank-x8898393
Old 02-11-2021, 06:05 PM   #6
Manitoba
Thanks - fingers crossed that they will ship to Canada. The problem seems to be that our Trillium tanks are so blasted flat (under 6") - making them a peculiar niche market item.
Old 02-12-2021, 12:31 PM   #7
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Shirlon Plastics in Cambridge ON.
they used to make a huge variety of tanks, They might still have an online catalogue, I got a black and a grey off the shelf, with outlets put where I needed them
Joe
Old 03-27-2021, 08:52 PM   #8
Manitoba
Final outcome
Hello all - I ended up getting the good folks and D&M Plastic, in Alberta, to custom-make a freshwater tank (about 43 litres), which they shipped to me in Winnipeg. Altogether, it ended up costing about $450 - which seemed a fair price in order to be able to have an independent water supply.
Old 03-31-2021, 01:01 PM   #9
David Tilston's Avatar
Susan, how much of the $450 was shipping?
Did you get them to install a marine deck fitting to make cleaning possible?
Old 03-31-2021, 01:11 PM   #10
Manitoba
Hi Dave - My total bill from the good folks at D&M Plastics (Alberta) was $478.32, inclusive of all taxes. Shipping costs (pre tax) by Canada Post were $47.14 (to travel two provinces over.) I don't know what 'marine fittings' are - so expect the answer to your second question must be 'no'! I do anticipate annual cleaning of the water tank and lines using some non-toxic cleaners.
Old 03-31-2021, 03:28 PM   #11
Susan, The fitting I was referring to would be better described as an inspection hatch:
https://www.amazon.ca/Hoffen-Hatch-W.../dp/B07PQ7C1R7
Name:	Inspection Hatch 01.JPG
ID:	140052Click image for larger version
Name:	Inspection Hatch 02.JPG
Several people have installed them on the top of their water tanks. They make scrubbing the inside of the tank possible. The position at the top of the tank would mean that the deck plate is not in contact with the water very much, so leaks are not likely. However, it should be noted that the deck plate is not rated for use with drinking water, though ABS plastic is commonly used in potable water service.
Old 07-06-2021, 12:43 AM   #12
Trailer: Trillium
Susan, how did your tank turn out? Do you have the specs/dimensions of your tank or the name of who you dealt with? Anything you would have changed with the design you ordered? I also need a tank and live in Alberta.
ButlerG is offline   Reply With Quote
Old 07-08-2021, 08:19 AM   #13
Manitoba
Hi - We are very happy with the replacement freshwater tank from D&M Plastics, in Alberta. Dimensions and sketch below. You can also email me at Susan_Prentice@umanitoba.ca, for more details. Total cost was reasonable, I thought: they amended a standard tank (RFW1003), then shipped. We paid a total of about $450 total, including delivery, to receive the tank in Winnipeg. It is SO handy to have reliable water on-board!
trillium
Do you drink the water in your freshwater tank? sunnyone General Chat 42 08-14-2020 05:08 PM
Hole in Boler freshwater tank SK_Boler_Cpl Plumbing | Systems and Fixtures 8 07-12-2020 10:33 AM
Replacing Freshwater fill spout? Richard Davis Care and Feeding of Molded Fiberglass Trailers 35 07-26-2017 12:29 PM
leak at filler tube on freshwater tank DogHaus Problem Solving | Owners Helping Owners 22 11-03-2012 05:20 PM
Last little thing - a freshwater leak JenPB Problem Solving | Owners Helping Owners 2 07-21-2008 11:14 AM
