Trillium Belly Band Repair - Fiberglass RV
Old 09-09-2021, 11:55 AM   #1
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Hello,
After only 42 years in AZ the Trill 1300's belly band started falling off.
So the rest of the rivets were drilled out to completely remove the band.
Filling, sanding, and painting were considered as a repair method.
Since the main effort was to keep the Trill as stock looking as possible
gluing the old band back on was chosen. On the internet some fancy silicone
adhesive was purchased sent from England. Number 4 sheet metal screws,
number 6 screws, and small washers were used to hold the band on while the
silicone cured. The top half of the band was filled down over the rivet holes
with the silicone before screwing the band on. The bottom was left open to
drain any water that might get in. Of course, after scuffing and cleaning the
fiberglass where the adhesive would contact, the band and trailer body were
masked off to protect them from all the silicone ooze out. For the finishing
touch new belly band trim plastic was installed. The result is quite pleasing..
Hmmm... Next project? Perhaps the sagging door?
Uncle Larry
p.s.: Special thanks to member David Tilson for supplying a missing trim piece!
Larry C Hanson is offline   Reply With Quote
Old 09-09-2021, 02:25 PM   #2
David Tilston's Avatar
That looks good! I am glad to help. Especially since I would have thrown them away in the end.
trillium
Belly Band repair Johny Bg Problem Solving | Owners Helping Owners 7 03-23-2021 08:15 AM
Trillium belly band--possible new repair method Francis C Care and Feeding of Molded Fiberglass Trailers 7 10-08-2013 04:28 PM
Trillium Belly Band Randy Bishop Problem Solving | Owners Helping Owners 9 05-16-2013 05:00 PM
Trillium belly band rivet removal Mike and Sarah K Problem Solving | Owners Helping Owners 14 02-24-2010 03:20 PM
trillium belly band Barry Konkin Problem Solving | Owners Helping Owners 3 01-21-2009 05:13 PM
