The Harbor Freight looked great so I bought it. A couple days later put it on and it only would go to the groove for the snap ring, ugh! Bought one at Lowe's. It was a Reese about 12 dollars more fit perfect on the stub BUT, The pin was bigger and it had this weird slant that place the wheel under the A. Had the bright idea of using the double pin from HF jack on the Reese jack. That plan didn't work out ideally as the Reese jack had a larger hole. Had to go to the brother who welds. He found the time to help me. We cut off the original bracket and welded it on the Reese jack.
Painting it up now so the welds don't rust. Now I feel safe when I am cranking it up. Thanks Bob for putting me on the path to local buying. Some things are best in your hands.
