Burro headliner - Fiberglass RV
Old 03-06-2020, 09:39 PM   #1
Trailer: Burro
Alabama
Burro headliner
What type adhesive to use to stick reflectix first and then to glue carpet to reflectix on ceiling of 82 Burro
janicedfields is offline   Reply With Quote
Old 03-07-2020, 07:46 AM   #2
Missouri
what i used on our 40f bus
I used some sort of glue that came in a gal can. rolled it on and it stuck good.
check the hardware store cant recall the brand
bob
Old 03-07-2020, 07:54 AM   #3
Jon in AZ's Avatar
Automotive headliner adhesive is another good bet.
Old 03-07-2020, 09:08 AM   #4
Missouri
not sure
jon it seems like it was headliner glue but 15 years ago cant remember! but whatever it was it worked but it would make you dizzy while applying it! I put 1/4 in foam then glued naugauhyde to that.
LOL
bob
Old 03-07-2020, 09:24 AM   #5
charlsara's Avatar
Trailer: 2014 Lil Snoozy
I used high temperature spray contact cement. Make sure it is high temperature. Another guy I know did it with standard spray and it came loose.
charlsara is offline   Reply With Quote
Old 03-07-2020, 10:27 AM   #6
Jon in AZ's Avatar
LOL
bob
Most of the products mentioned in this thread will do that. Ventilate well.
Old 03-21-2020, 02:02 PM   #7
Trailer: Amerigo
Wisconsin
I was an installer of those types of products for many years my first question is why reflectix? If for insulating I would keep looking for a better product. Amazon has many peel and stick automotive sound deadener insulation. The "carpet" is not so much a carpet as nice looking sound deadener. I had a motorhome where ceiling had this acoustical carpet on the ceiling. That is what I would look for it is light weight and is much easier to install than conventional carpet. Acousta-chord is a brand name that comes to mind. Most time i would precut a sheet leaving extra to trim off. Conventional wall covering adhesives do work if paste both the surface and the goods allow to dry somewhat until tacky, then apply. I think you could use carpet glue also on the surface then press the goods into the glue, using a small piece of plexiglass. ( Well rounded corners and edges) working overhead you need to think like and octopus or have a very close friend nearby......
bigangelman is offline   Reply With Quote
burro
Carpet & Headliner Replacement help - New Burro Owner! Armymomma Problem Solving | Owners Helping Owners 20 07-23-2016 07:47 AM
Burro Headliner Fiberglass-Is this fixable? Crystal and Jason Care and Feeding of Molded Fiberglass Trailers 12 06-18-2016 04:22 PM
Burro "Headliner"issues Edward83burro Problem Solving | Owners Helping Owners 11 08-23-2011 08:14 AM
Burro headliner with LED strip kyle minor Modifications, Alterations and Updates 10 07-12-2010 04:42 PM
