tongue weight seems high for 13' Burro - Page 2 - Fiberglass RV
Old 07-10-2020, 06:03 AM   #21
Jon in AZ's Avatar
So if you won’t be carrying propane, how will you run the 3-way fridge? Will you always have electric hookups?
If you want a propane option with minimal tongue weight, there are smaller 11# tanks, available in steel or composite. Pricey, you have to watch the level loosely, and you can’t use the 24-hour convenience store propane exchange in a pinch, but handy. They’re a lot more earth-friendly than disposable cylinders.
https://www.acehardware.com/departme...essories/80244
https://www.homedepot.com/p/Worthing...1165/202034839
You could also relocate the battery to a vented box in one of the rear compartments.
If the current 154# is correct you’ve got about 20# to play with. A tongue weight of 135# is about 12% of 1100#. That 1100# is gross weight, not axle weight, right?
burro, weight
is my weight distribution hitch worth the tongue weight and effort. beachcamper54 Towing, Hitching, Axles and Running Gear 24 01-25-2014 12:41 PM
Tongue weight or hitch weight Cathi Towing, Hitching, Axles and Running Gear 26 04-23-2012 11:38 PM
1985 Burro 17' seems to be sitting too low shumiron Towing, Hitching, Axles and Running Gear 9 10-28-2011 01:55 PM
What if your tongue weight is too high? cpaharley2008 Towing, Hitching, Axles and Running Gear 15 09-26-2011 10:13 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 08:49 PM
