Trillium 1300 bulbs - Fiberglass RV
Old 05-16-2019, 04:28 AM   #1
kg8jk's Avatar
Trailer: '77 Trilliium 1300
Trillium 1300 bulbs
Hello,
I need to know what size bulb the running lights are on a 77 Trillium 1300. Can't seem to figure that out as no markings on them.
Also, what bulb would you recommend for switching the interior lights to LED? I would like them to be nice and bright but not use up so much battery as we boondock a lot.
Thanks. The Trillium and I are off to the Dayton Hamvention. Our first camping trip this year!
kg8jk is offline   Reply With Quote
Old 05-16-2019, 07:15 AM   #2
Forget bulbs. Just get replacement LED fixtures.
I also bought replacement LED marker lights for the outside of the trailer and removed the guts for the rear lights, and replaced them with LED (still using original lenses).
1977 Trillium LED lights by wrk101, on Flickr
fullsizeoutput_a72 by wrk101, on Flickr
fullsizeoutput_a73 by wrk101, on Flickr
Old 05-16-2019, 08:05 AM   #3
John in Michigan's Avatar
Trailer: 1979 Boler 1700
thrifty bill, can you provide the brand and part number for the taillight fixtures that you retrofitted? I'm using three(!!!) 1157 LED bulbs in each taillight fixture and its still not very bright, so I'd like to try your solution.
For the interior lights, I am just using low quality 1156 LED bulbs and am satisfied with this. If I were buying today, I would look for brighter 1156 LED bulbs with a wider voltage range rating, e.g., 10 to 30 volts in order to accommodate voltage swings in the camper. Others have recommended superbrightleds dot com as a good source for LED bulbs.
Old 05-16-2019, 08:10 AM   #4
Bought on eBay. Several sellers with them. I need to drive behind my Trillium at night to see how well they work. Got the clear ones as any color will reduce output when run through stock lens.
The only reason I did not go with LED replacement bulbs is the fixtures were broken. Otherwise, LED bulb in the tail light would have been a good choice.
I don't see the exact ones I bought on Ebay right now, but I see similar units for under $20 for the pair. I had to trim the housings a bit, basically the black flange. Did not cut into the sealed portion.
On my interior lights, some of the housings were cracked, others had lenses that were yellowed. Replacement was the easiest route. I also added more light, using double light units where single lights were located. The LEDs cut amp draw by about 90%, so adding lights still put me WAY under the draw of the originals. More like a 80% cut instead of 90%.
Something like this, you want clear light when you put a stock lens over it. Most of the ones for sale are either red or amber:
https://www.ebay.com/itm/1Pc-White-1...UAAOSw3HpcmSXy
Old 05-16-2019, 08:25 AM   #5
OK thanks thrifty bill. Just checking superbrightleds dot com, they have an oval truck and trailer taillight $19.95 each, that can be ordered in clear that is 450 lumens. That should do it.
Old 05-16-2019, 10:30 AM   #6
This one looks interesting, not sure about measurements.
https://www.ebay.com/itm/1-Pcs-White....c100005.m1851
trillium
1988 Bigfoot Trailer Light Bulbs V'sGlassSleeper Problem Solving | Owners Helping Owners 9 07-19-2020 01:24 AM
Bulbs Replaced With LED's in Escape - Fantastic! dkdavies Modifications, Alterations and Updates 9 05-31-2008 11:28 PM
LED light bulbs for Scamp ted saxton Modifications, Alterations and Updates 0 09-18-2007 04:35 AM
LED taillight bulbs Alistair Camelford General Chat 9 11-10-2006 01:39 PM
Bulbs and Lighting Legacy Posts Modifications, Alterations and Updates 11 05-15-2003 09:53 AM
