Fiber Stream Resources - Fiberglass RV
Old 08-11-2019, 09:21 AM   #1
OR335d's Avatar
Name: Randy & Ranae
Trailer: Fiber Stream
OR - Oregon
I've collected quite a bit of information about the parts and systems in a Fiber Stream from tearing it down to a bare shell. I'm going to start posting some information that might help others as they work to improve theirs. First item, wiring diagram. This is broken up between towing wiring, 110V, and 12V. Please let me know if you have any questions. By all means, remove the stock converter ASAP as it is known to severely shorten your battery life. If not, disconnect the battery when not in use.
Please let me know if there are any other systems, parts or appliances you are wondering about and I'll get that information up sooner than later.
File Type: pdf Fiber Stream Stock Wiring 1983-Reduced.pdf (208.7 KB, 55 views)
OR335d is offline   Reply With Quote
Old 08-11-2019, 09:44 AM   #2
OR335d's Avatar
Name: Randy & Ranae
OR - Oregon
Fiber Stream Brakes
One of the rare items on a Fiber Stream is the axle and brake combination. They were manufactured by a GM subsidiary in CA, but a GM settled a strike by closing down the factory in the 1980's. An oddity is that the outer bearings are a different size than the inner bearings. The parts will not swap with any other axle. You can replace with a new axle, or look for parts from a dead Fiber Stream. Other magnets could be retrofitted, and break linings can be re-manufactured. I've attached a diagram from a tent trailer that used them. They were also on some Airstream Argosy trailers. I have done extensive searching, and there are no original parts available. The bearings are common sizes and can be ordered from your local bearing supplier. Please post if you have actual product information for these.
File Type: pdf 1983 Fiber Stream Brakes-Reduced-Reduced.pdf (57.4 KB, 42 views)
Old 08-12-2019, 02:19 PM   #3
Trailer: fiber stream
I'm wondering if you know a source for side window screens?
Jackie
kiyiyi is offline   Reply With Quote
Old 08-27-2019, 09:14 PM   #4
Frame reinforcement
Hello again. I hope I am replying correctly. I feel I will probably have to do a frame reinforcement. The frame appears to sag down behind the axles and the little outrigger supports look a little dog eared all around the perimeter. Would you mind giving a little run down on the specifics of what you did to yours?
Sam Roberts
Sam Roberts is offline   Reply With Quote
Old 08-29-2019, 03:53 AM   #5
trainman's Avatar
Trailer: 2019 Oliver Elite II
Being a retired body shop mgr. for over 30 years it still remains why anyone would tackle a restoration that can not fully do the job themselves and with the knowledge needed to do it. I don't care what it is, auto, boat, trailer, home, etc., it's expensive with even you doing all the labor and in most cases it's done at a $ loss and not profitable, ok, I'll buy the restoration thing for a hobby. I restored several things when I managed the body shop, but I also had a lot of free help, otherwise I wouldn't have even attempted any of them. I almost restored a Airstream Argosy at one time, then I came to my senses and passed on the idea.
trainman
trainman is offline   Reply With Quote
Old 08-29-2019, 04:35 AM   #6
OR335d's Avatar
Name: Randy & Ranae
OR - Oregon
Fiber Stream Frame Reinforcement
Sam Roberts
Sam,
The frame is coming up soon on my list of things to do. When these trailers are new the shell and interior partition walls add significant strength to the frame. In my estimation the frame is not strong enough on its own. A common failure happens when moisture leaks in the door area, softens the plywood floor, and allows the floor to sag at the rear wall of the fridge. There is no frame where this cabinet passes the load to the floor. When the floor sags at this point, the entire load of the trailer must be carried by the frame rather than be distributed by the shell.
Others have added steel to the frame. The Drivin and Vibin Youtube channel has a little information on what they did. I anticipate adding 1" tube to the bottom of my frame in the coming winter season. It would be great to see what others have done as well. I might need to flip the axles to provide enough room.
Old 08-29-2019, 07:19 AM   #7
Restoration
The whole idea of restoring a fiber stream is insane. I’ve accepted that. When viewed as a whole, the task is daunting. I have decided to put blinders on and tackle the project in little bites. As of now, I have flipped the axles, added 13 “ radials,installed A/C, Fixed most of the leaks in the shell, added metal roof vents, removed most of the rotten flooring and replaced with 1/2” outdoor sign board which will be coated with epoxy resin. That heavy fridge pounded right through the floor so it had to go. Looking for replacement. Next on the list is removal of sink, stove,,cabinet and floor panel beneath it all. Once I get an empty shell, I ‘ll decide If I need to do the frame work myself or tow to my local welding shop. So far, this has been a fun project.. Sam
Old 09-01-2019, 10:54 AM   #8
Thanks for the info! We are restoring an old FiberStream, as well. I'll post photos asap.
MsRat3 is offline   Reply With Quote
Old 09-01-2019, 03:14 PM   #9
Would love to see your progress!
Old 09-26-2019, 04:36 PM   #10
my flooring in some places is a little mushy, gonna add some 1 inch steel soon, flipped my axles, made a world of difference, I can boondock better now. thanks! Dave
dclayton is offline   Reply With Quote
Old 10-28-2019, 06:30 PM   #11
Any information on where to find the windows weather strips?
Ghos is offline   Reply With Quote
Old 11-03-2019, 09:05 AM   #12
OR335d's Avatar
Name: Randy & Ranae
OR - Oregon
Window Weather Strip
Haven't found the weather strip for the windows. I'd really like to, as when we rebuilt our windows we reused the old, and it's shorter now.
Old 11-20-2019, 08:58 PM   #13
No lock, but we will let you know what we ended doing. Love the trailer, but it has been a pain...
Old 11-21-2019, 07:27 AM   #14
trainman
Agree mostly. I have at least 300 hours into my Trillium rebuild, probably more. Let’s say I paid someone to do this work, and I will assume they would be more efficient than me. At local rates (at least $75 an hour) and let’s say 200 hours, that’s $15,000! Clearly a 1977 Trillium is not worth that expense. As far as my hours into the project, I consider it entertainment. I’m not looking for a return on my hours. And I am not done!
I own two vintage homes right now. On one, the inspector told me “do not buy this house!” And on the other, the inspector told me the house was too far gone, it would have to be torn down. Well I’m stubborn and do 99% of the work myself, so I rebuilt both of them. Most of the expense was my labor. Had I paid someone to do the work the expense on either would have been double or triple what the finished homes are worth,
Old 11-27-2019, 05:38 PM   #15
Sam,
I had an idea on reinforcing my frame that I wanted to run by you. Since I am currently in the process of replacing my floor, I have full access to my frame. Do you think I might be able to run a piece of 1"x1" tubing under my existing 1"x2" frame (front to back only)? Instead of welding it on, I would like to "strap" the two pieces together with some some flat mending plate metal or modified U-Bolts. This would allow for some amount of flexibility as opposed to welding(which according to another reader, comes with its own set of problems).
Old 09-10-2020, 06:42 PM   #16
Trailer: 1982 Fiber Stream
Nevada
Looking for plastic u shaped trim for trim on bathroom/closer and divider walls.
I am looking for the plastic u shaped trim that caps the bathroom door and dnt divider wall pass through window. I have searched all the places I can think of and have had no luck. I thought I would ask you if you are using that cap and if you found any new. The old stuff just wont do. Thanks,
Frank
canyon Rafter is offline   Reply With Quote
Old 09-12-2020, 07:46 PM   #17
Hi Frank.
I just gutted my Fiber Stream and threw out most of the interior. I just assumed I could easily find the mouldings when I went back in. I haven't looked real hard, but I found this website that might have something that would work. I will see what is left of mine and will message you back. Sam 210-415-1173
https://www.outwater.com/color-plast...nnel-moulding/
Old 09-13-2020, 11:00 AM   #18
Nevada
Plastic U Channel
Thanks Sam,
I have been looking for a source online and in the camper dealers here in Vegas for sometime now. This is the kind of source I have been looking for. I haven't looked real hard at this store but it looks like so far they might have just what I need! I totally gutted my Fiber Stream also and am on the last fazes of putting the camper on the road. I replaced a lot of the original wiring for the towing lights, new seven way plug and wiring I got from etrailer that has a j box that is well worth the bucks! New breakaway brake system also from the same store that is far advanced from the original and worth the time and effort. It has been a work of great satisfaction to see the Fiber Stream come back to life! I also added Weight Distribution System w/ Sway Control to make towing in the wind a little less stressful. When all is complete I will put up pictures on the Fiberglass RV website. It has taken me a while to get this project done but with the time off during this covid thing I have got a lot done this summer! Thanks for the online store!
Frank
Old 06-21-2021, 03:29 PM   #19
Trailer: Fiberstream
CA
Does anyone have any information on the size of the wheel bearing seal for a 78 Fiber Stream? Planning to repack it and I'll be doing it two hours out of town so hoping to get the part before starting the job. Thanks in advance.
FiberStream78 is offline   Reply With Quote
Old 08-09-2021, 11:04 PM   #20
OR335d's Avatar
Name: Randy & Ranae
OR - Oregon
Fiber Stream Bearings
I believe our trailers share axles and bearings with the Apache tent trailers from the same erra. Here's a link to the manufacturers information and diagrams:
Apache Trailer - Fayette Axles
Hope this works for you.
fiber stream
Hymer Touring GT owners & resources thread OCJohn General Chat 155 03-11-2022 10:25 PM
Rental resources for fg trailers? kelliegee General Chat 6 06-07-2016 11:33 AM
Traveling Job Resources? Pullnotpush General Chat 10 02-18-2016 07:15 PM
Fiber Stream Buyer General Chat 0 01-01-1970 12:00 AM
