1975 VENTURA window / door seals - Fiberglass RV
Old 04-13-2021, 11:56 AM   #1
Trailer: Ventura
Manitoba
Hi all I have a 1975 Ventura that's been stored in side for a lot of years
I am looking for part numbers and where to get, window seals and door seals
looking for the cranks for the windows (all)
Anyone know where i can find a replacement door window assembly.
I had to repair the door that fell off the hinges wood rotten inside due to window leaking I welded a frame on the outside and then made aluminum frame for the inside to slide inside the outside frame filled with hard styrofoam now good and solid and rain will not rot it out.
Curtis M is offline   Reply With Quote
Old 04-13-2021, 12:15 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Post some pics to help in identifying the windows. On older Hehr windows, the model number is stamped on the sill.
To find window parts such as cranks, torque operators, brackets and seals, check:
- Vintage Trailer Supply
- Vintage Trailer Gaskets
- Pelland Enterprises
- Interstate RV Metal and Supply
- All-Rite Custom Manufacturing
Old 04-15-2021, 07:16 PM   #3
Trailer: Ventura
Manitoba
Is there a particular corner that I can find stamping went looking tonight I could not find any model numbers
Old 04-15-2021, 07:27 PM   #4
Trailer: Ventura
Manitoba
Attached architects of window and camper
Old 04-15-2021, 09:27 PM   #5
River Robert's Avatar
Trailer: Trillium 1300
Windows
For the windows the serial number is stamped below the bottom rod usually around the middle. You may need to look close or whip some dust away because they can sometimes be hard to read.
Robert
River Robert is offline   Reply With Quote
Old 04-16-2021, 06:48 AM   #6
Agree with River Robert. On the Trillium three-pane side windows that look similar to yours, crank the window all the way open and look for model number on the top surface of the sill close to the middle. Cleaning and lots of light may help to view the number.
Old 04-16-2021, 07:16 AM   #7
Looking at your side window, the window pane brackets look different from my Hehr window brackets, so its possible you do not have Hehr windows. If they aren't Hehr windows, I don't where the model number would be located.
Our Trillium windows are Hehr series 4900.
Old 04-18-2021, 02:24 PM   #8
Trailer: Ventura
Manitoba
Well guys and gals I went out with a younger set of eyes and we still cannot find identifications
I have removed the screen and attached more photos maybe somebody will recognize this style of window
Old 04-18-2021, 02:27 PM   #9
Trailer: Ventura
Manitoba
I am unsure how my pics turn sideways they were initially orientated correctly LOL
Old 04-21-2021, 06:32 AM   #10
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Based on what I can see externally, it looks like they could be Hehr. Go to Vintage Trailer Gaskets using this link. It has pictures that show what the gaskets look like for each type of Hehr window. You might be able to determine what gaskets you need from their shape:
https://www.vintagetrailergaskets.co...railer-gaskets
The black plastic pieces on the outside of the window frame are standard screw covers:
https://www.vintagetrailergaskets.co...rew-cover.html
The grey piece overhanging the upper edge of the top window is the Top or Sill Seal:
https://www.vintagetrailergaskets.co...e-windows.html
Other than that, I can't see any of the other gaskets in the pictures.
Old 05-08-2021, 02:56 PM   #11
Trailer: Ventura 1973
Calgary
Not much help except to say that my 1973 Ventura windows are identical to yours. and I can't find serial numbers either. If you do have some luck, looking forward to your post. I need to change parts in my cranking mechanisms and don't know what I am looking for yet.
Parallel49th is offline   Reply With Quote
Old 05-09-2021, 07:04 AM   #12
order some samples
Curtis, to you and anyone else trying to find the correct gaskets/seals for your windows, order some samples. Go ahead and contact the supplier and request samples. We were able to order gasket/seal samples from several different companies for free or a small charge, then decide what fits.
Old 02-17-2022, 07:26 PM   #13
Trailer: Ventura
Edmonton
windows
I just rebuilt all my windows and used gasket from vintage trailer supply. Took the window completely apart and had to replace a few panes of glass. The only gasket I got locally was the one around the window glass that holds the window in the frame. I could only find a close match and had to pinch the aluminum so that it would grab. They all came out good though. I had some screws break on removal. I just used a die grinder with a cutter disk to cut most of the screw away and pounded out he remaining screw. Worked awsome. I do have pictures and will up load them to my rebuild thread some time this year.
TacomaJax is offline   Reply With Quote
ventura
« Uh oh! | Windows »
1975 Trillium Window Seals Carlost Problem Solving | Owners Helping Owners 7 06-18-2018 08:10 PM
Window seals for Ventura jalousie windows Patricia D. Problem Solving | Owners Helping Owners 0 03-05-2017 02:41 PM
Where to buy wheel bearings and seals for a 1975 Trillium 1300 Roadsterrv Towing, Hitching, Axles and Running Gear 5 10-02-2015 11:32 AM
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
