Bigfoot B17CB TV?? - Fiberglass RV
Old 01-21-2020, 01:16 PM   #1
Question Bigfoot B17CB TV??
Hi everyone,
I've got a 1995 Bigfoot 17CB and would like to install a TV, etc. and am looking for suggestions, recommendations, photos of what others have done.
Phil
Fullbooker is offline   Reply With Quote
Old 01-22-2020, 12:28 PM   #2
Trailer: Trillium
Hi, I don't have the same trailer as you so you need to get suggestions about where to install the TV from other members. I just want to suggest to you that most NA TV stations broadcast live HD TV, so if you plan on using an antenna installed outside or inside using cable wire, it is best to have the antenna installed so that you can change direction of reception at each location and make sure that the antenna is NOT grounded. You will then need to turn the TV on and use settings (cable option) to get the best reception.
jokra is offline   Reply With Quote
Old 01-22-2020, 01:14 PM   #3
Trailer: 13' Perris Pacer
Thank you for your clarification that "TV" can mean more than "Tow Vehicle."
mchalewj is offline   Reply With Quote
bigfoot
CA | SOLD: Bigfoot 15 B17CB 2002 $12,000 Babbs in CA Classified Archives 21 07-11-2017 12:43 PM
B17CB....furnace....(just because it's so quiet around here;)) Franswa Modifications, Alterations and Updates 3 06-03-2014 10:28 PM
Bigfoot B17CB issues...help!!! DwayneR Problem Solving | Owners Helping Owners 8 06-27-2009 12:29 PM
'02 Tacoma towing Bigfoot B17CB DwayneR Towing, Hitching, Axles and Running Gear 16 06-22-2009 01:56 PM
1995 B17CB Bigfoot - Ball Height Dave R Towing, Hitching, Axles and Running Gear 2 08-02-2008 09:20 PM
