Parkliner - Fresh Water Tank - Fiberglass RV
Old 05-18-2019, 09:37 AM   #1
Trailer: ParkLiner
Virginia
I just finished a thorough cleaning of my 2014 Parkliner and noticed 1 of the 2 straps that holds the fresh water tank in place is broken.
Do I need to take the tank completely out to replace the strap and how difficult is it to remove the tank? Thanks
Old 05-19-2019, 01:20 PM   #2
Where did it break? If it's like ours, the straps are made of steel strips with holes all along. The ends are bent out at an angle and bolted together with long screws. You may be able to splice the break with another piece of the same material. If it broke somewhere under the tank, Then yes, you would probably need to remove the tank.
Old 05-19-2019, 03:03 PM   #3
Sid
Sid's Avatar
Trailer: Parkliner 2014
Wisconsin
Wayne,
I believe you are describing the black water tank under the camper.
Huck was referencing the fresh water tank inside.
Or was he wrong? I’m confused ....
Sid
Sid is offline   Reply With Quote
Old 05-19-2019, 03:17 PM   #4
Originally Posted by Sid View Post
Wayne,
Sid
No, I think we're both talking about the black FRESH water tank inside under the bed.
wc
Old 05-19-2019, 05:59 PM   #5
Sid
Sid's Avatar
Wisconsin
Thanks Wayne!
Old 05-27-2019, 04:39 PM   #6
Trailer: ParkLiner
Virginia
Yes, the freshwater tank inside the trailer. The strap rusted out under the tank. I think I have a fix that doesn't require removing the tank thanks to another member.
I'll post the fix when I get it done.
Old 08-04-2019, 06:18 PM   #7
Trailer: Parkliner
Huck,
Hopefully you can repair the strap, pulling the tank will not allow access to the bottom of the strap, it is actually attached to the bottom of the board with screws and then the board is glasses into rhe shell. Which side of the strap broke, in front or behind the tank? Also if the tank strap rusted the you had or have a leak from somewhere on or around the tank. If there is a leak and not addressed it will cause more damage that may not be eaisly repaired.
AmcGee is offline   Reply With Quote
Old 08-05-2019, 08:17 AM   #8
Trailer: Parkliner
Maryland
We would be interested in any thoughts regarding the water issue that caused your strap to rust. We have mysterious water accumulation under our water tank. We think it’s coming in the electric cord hole but not sure it holds true for all previous cases. It’s a mystery, and a pain in the ass to get the water out of there.
Doggonehappy1 is offline   Reply With Quote
Old 08-06-2019, 05:33 PM   #9
Trailer: Parkliner
Beth,
Is there holes in the bottom of the shell below the fresh tank? Also there are a few things it could be , the fresh fill could be leaking, the lower fitting on the tank could be leaking, the crossover pipe at the very rear of the floor could be leaking, the tank could have a hairline crack at the bottom, the clamp at the low point drain, the fittings for the water pump could be leaking. All of these are things I have seen first hand.
Old 08-06-2019, 06:31 PM   #10
Trailer: Parkliner
Maryland
Thanks Aaron. I will run this list by Ross. I know he has done a dozen tests to try to pin it down but it must be one that you have mentioned. Stay tuned...
parkliner
city water fills fresh water tank drmarylynn Plumbing | Systems and Fixtures 10 05-23-2017 08:35 AM
Casita - water from fresh water tank charleserwin Problem Solving | Owners Helping Owners 20 12-30-2016 04:43 PM
Auxiliary Fresh Water Tank, Transferring Water Adrian W General Chat 0 09-05-2010 02:36 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
