Beachcomber TM15 ‘79 Replace Plywood Floor - Help! - Fiberglass RV
Old 06-06-2020, 11:03 PM   #1
Trailer: Beachcomber
Hello! Just bought a Beachcomber TM15 ‘79. Extensive floor rot so replacing plywood. All the Beachcomber floors I have seen have an inset into the fiberglass that allow for wood “cross beams” - mine does not have these. The plywood was layed directly on the fiberglass.
My question: I was planning on glueing down 1/2” x 3” cedar “cross beams” then laying the plywood floor on top of those and then running carriage bolts through both to the frame.
I would love advice on how to do this, if it’s a good idea, etc Or do I need to have the “cross beams” at all?
The 1st photo of the cleaner fiberglass floor is not mine - but is another Beachcomber floor to show as an example of the “cross beams” that I will try to replicate.
The other fiberglass floor is mine (showing no cross beams).
3D69D80A-2EB5-4646-B5A1-A98CD86D7F1B.jpeg   C44A4F37-1E20-42BF-9E18-B9361BFF7EF7.jpg
Teresa in Oregon is offline   Reply With Quote
Old 06-07-2020, 01:29 AM   #2
Saskatchewan
I would definitely put the cross braces in. There is not much to these floors so every piece of wood is important. I have a few images on my thread.
Joshua is offline   Reply With Quote
Old 06-07-2020, 09:27 AM   #3
FL
Just throwing this out there. I have rebuilt a pathfinder and a ranger boats floors. No wood . Made new stringers “flooring braces”using board made from honey comb sheeting and layered unidirectional fiberglass Glassing to hull/shell . For decking/flooring used honey comb fiberglass sheets and expanding adhesive to the stringers.and glassEd sheeting to hull, but would be easy to make the sheeting “loose” like your wood sheets, if a camper needs more flex than a 22’ bay boat. . Finished with gel coat. Big job but both boats turned out great. Would think boat tech. will transfer to campers . Wood rots , plastic is forever. There are lots of how to’s for replacing boat “floors”decks .
mosquito13 is offline   Reply With Quote
Old 06-07-2020, 04:25 PM   #4
Thanks for the info!
beachcomber
Beachcomber TM15 - The build, starting with gutting the inside Rick n Modifications, Alterations and Updates 109 11-19-2021 11:07 PM
Beachcomber B15 & TM15 goggles General Chat 1 08-07-2019 11:50 AM
Beachcomber TM15 Hand Pump syd1953 Plumbing | Systems and Fixtures 1 07-31-2017 10:24 AM
'78 Beachcomber TM15 - Advice Please jgrilo1 Problem Solving | Owners Helping Owners 2 05-07-2015 03:06 PM
About to become the proud owners of a Beachcomber TM15 Ellie P. Hi, I am.... 3 08-30-2012 10:51 AM
