Bigfoot rear window seal replacement - Fiberglass RV
Old 08-05-2020, 05:08 AM   #1
BC
Just wanted to share my experience fixing the rear window on my 2004 bigfoot 17. The butyl tape was getting very cracked and brittle at the top corners but the big problem was the foam seal that seals the window shut for the emergency escape was pulled at all 4 corners. So water was easily coming in when it rained.
I unscrewed all the screws from the inside and pulled the inside frame off. Next I used a putty knife to crack the butyl seal on the outside. Spent 2 hours getting all the old glue off the foam tape with alot of elbow grease and mineral spirits.
I found black butyl tape at lordco and the foam I used was from Amazon in 15 foot lengths ( there is actually 2 foam seals I replaced) I knew I wouldn't have been able to properly clean all the old glue to get a good stick with the new foam so I pulled the window.
https://www.amazon.ca/gp/aw/d/B07C366Z6R?psc=1&ref=ppx_pop_mob_b_asin_title
Amazon link to foam seal was the exact size I needed plus quality 3M peel off backing. 2 - 15 foot lengths for 21 bucks
Black butyl tape is proform brand in also in 15 foot length
Finished it off with RV ezee gutter to keep the water off.
Mooncusser is offline   Reply With Quote
Old 10-08-2020, 12:07 PM   #2
Trailer: Bigfoot 17
Well done!
Doug Barlen is offline   Reply With Quote
bigfoot
Replacement Rear Window seal on Bigfoot 13.5 greg0066 Problem Solving | Owners Helping Owners 4 04-10-2017 05:26 AM
replacement window glazing for rear window on 1975 scamp Josh Wink Problem Solving | Owners Helping Owners 6 07-15-2016 04:05 AM
Front/Rear Window seal rubber nelsons Care and Feeding of Molded Fiberglass Trailers 8 04-29-2014 12:33 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Scamp (curved) front & rear window seal, Help Eddie Longest Problem Solving | Owners Helping Owners 4 02-03-2010 09:57 AM
