Revamping inside a Cadet Trailer - Fiberglass RV
Old 03-16-2012, 12:15 PM   #1
Trailer: Cadet
Quebec
Hello! This is my first message to this forum. We have a 13-foot, 1985 Cadet trailer. Only problem is the inside, red lining, of velvet-type fabric lined with a thin layer of foam. This lining has become more and more unglued, for instance along the door. Also, some of it is now floating a few inches below the ceiling. We aren't equipped to pull it out as some seem to have done. But we have tried different ways to glue it back on. First, different types of tape including double-sided velcro, to no avail. Last big attempt, recommended by a specialty outlet: a somewhat toxic 3M Super Spray Adhesive. This lasted longest so far: 48 hours before getting undone again.
Would someone have found a solution to this problem? Otherwise this little gem of a trailer has been pretty good.
Jocelyne Gauvin
Montreal, QC, Canada
Jocelyne Gauvin is offline   Reply With Quote
Old 03-16-2012, 03:14 PM   #2
Trailer: 86 Cadet
I'm in the process of re-doing the inside of my Cadet. I tried a few things to get the existing stuff to stick and had no luck. The pop-up ceiling was the worst so I just took it off, cleaned all the old foam and glue off with a wire wheel and glued Reflectix on to the fibleglass with contact cement and vinyl on to the Refelctix, again with contact cement. Its been two months and so far so good so I will use this combination on the rest of the inside.
daveterp is offline   Reply With Quote
Old 03-16-2012, 06:18 PM   #3
Hi Jocelyne, I just wanted to take the time to welcome you to FiberglassRV. We're glad you're here! I've always liked the Cadet... cool little trailers. Do you have any pictures you'd like to share?
I'll leave the answer to your question about glue to the experts. You'll find lots of kind, helpful people here on FiberglassRV.
Old 03-16-2012, 06:42 PM   #4
Pam Garlow's Avatar
Trailer: U-Haul 1985
Cadets are my favorite trailer as far as outside styling. They are so unique!! love to see photos
Pam Garlow is offline   Reply With Quote
Old 03-16-2012, 08:03 PM   #5
Trailer: 86 Cadet
Hi Jocelyne, I have used PL300 Lepage Foamboard Adhesive to glue flexible foam to the fibreglass surface of my Cadet. It's been 7 months and it's still holding. This glue should work. Just follow the directions on the tube.
jmark is offline   Reply With Quote
Old 03-17-2012, 06:53 PM   #6
Steve Hilby's Avatar
Trailer: Compact Jr
It sounds like the material used was like automobile headliner, a foam-backed velour material. What's happening is that the foam is disintegrating. You can try to glue it back up, but the foam will disintegrate a bit more and down she'll come again.
On my old Dodge Omni, I pulled the headliner cardboard out and a local upholsterer glued on new material for a very reasonable price. Probably not practical for your trailer, though.
Steve Hilby is offline   Reply With Quote
Old 03-17-2012, 07:37 PM   #7
Carol H's Avatar
I have used the 3M Super Spray Adhesive on the rat fur on my scamp with good results. Found it best to spray the material and wait a min before sticking it to the wall.
Old 03-20-2012, 12:30 PM   #8
Trailer: 86 Cadet
Think about the temperature while using the 3M products. 3M says best results at 65 degrees (18C) or more. Current temperatures on the West Coast are well below that and the Spray 90 is taking a lot longer than 1 minute to set.
Old 03-21-2012, 08:38 PM   #9
Trailer: Cadet
Quebec
Hello!
Many thanks to all who sent me comments and suggestions for gluing back the inner lining of our Cadet 13-foot trailer. We're looking forward to trying some of these ideas during spring. Other suggestions will be welcome also.
Jocelyne Gauvin
cadet
Do you park your trailer inside or outside? Dale AZ General Chat 46 03-27-2014 03:15 PM
Cadet Travel Trailer - 1985 - $4500 David Tilston Referrals: Molded Fiberglass Trailers 5 02-12-2012 11:26 AM
Cadet Trailer Window Lonnie W Problem Solving | Owners Helping Owners 1 07-05-2011 02:19 PM
Inside Trailer Height Doug Mager General Chat 15 09-10-2008 11:40 AM
