Hi All! New Bigfoot owner needing help here! - Fiberglass RV
Old 05-06-2020, 11:32 AM   #1
Trailer: Bigfoot B-16
Hi all!
I recently purchased an early 80’s Bigfoot B-16 trailer, and it is in need of a tremendous amount of work! The roof vent has been broken for a couple years, and the whole ceiling is toast, as well as the floor, and at least the front wall.
I’m located in Calgary, AB. Has anyone had experience rebuilding one of these units?
I’m feeling a bit overwhelmed, not sure if I can do all the work! Luckily I have a large garage, so it’s parked inside, not getting worse outside!
I look forward to learning from y’all!!
Cheers
Dan
Calgary Dan is offline   Reply With Quote
Old 05-06-2020, 11:05 PM   #2
Trailer: 1974 Boler and 1988 Bigfoot
Wow sounds like you have a real job on your hands. Sounds like to me it is a total rebuild inside. I think the best is to just start taking things apart. Once you have things removed you will have a fiberglass shell. Who knows where water has gone and mould is growing. If you search on this website there is a total rebuild of a 1979 17ft like yours. I think thread will give you lots of help. Here is the Thread. I hope it comes up if not just search it. Good luck and keep us up to date with all your projects with pics.17 ft '79 bigfoot - restoration/modification thread.
Rick M is offline   Reply With Quote
Old 05-06-2020, 11:18 PM   #3
Well I will try again to send this persons Reno of his 1979 17ft Bigfoot.https://www.fiberglassrv.com/forums/...ferrerid=18966 Good Luck.
Old 05-07-2020, 03:03 PM   #4
bigfoot
Mike in Edmonton i use ozone to kill mold and icky bugs easy to do .i alsodo renos on these.
bigfoot
« new member | Hello »
New guy needing Bigfoot advice Travelin2 General Chat 21 08-11-2018 06:41 PM
New Burro owner needing parts nadam78 Problem Solving | Owners Helping Owners 6 09-14-2015 02:35 PM
Our new addition! Needing all the help we can get! The Garrisons Problem Solving | Owners Helping Owners 13 04-04-2015 08:23 AM
Needing help for above the Stove Cabinet Anne3358 Care and Feeding of Molded Fiberglass Trailers 7 02-13-2010 02:10 PM
Needing help for above the Stove Cabinet Anne3358 Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
