Fiber Stream roof - Fiberglass RV
Old 08-27-2020, 09:58 AM   #1
Trailer: Currently Shopping - Fiberstream
Minnesota
Fiber Stream roof
Good morning.
My 1984 Fiber Stream has a rooftop air conditioner unit. Last night I noticed water dripping inside the trailer. I want to clean our the rooftop unit. My question, can I stand on the roof of my Fiber Stream? or should I plan on working on it from a ladder? Tips or thoughts appreciated.
Rich
rmcgeher is offline   Reply With Quote
Old 08-27-2020, 06:41 PM   #2
OR335d's Avatar
Name: Randy & Ranae
Trailer: Fiber Stream
OR - Oregon
Fiber Stream Roof Loads
I wouldn't put a load on the roof of a Fiber Stream. The air conditioner, when installed, is in the strongest part of the roof between the fridge cabinet and the little pass-through window wall. These two structures are the only thing that keeps the walls from bulging out due to the forces of the roof. I've seen a few where the screws from the outside going into the wall and fridge cabinet have decayed, and the walls bulged out significantly. If you've torn a Fiber Stream apart before, you'll know that these walls and cabinets are extremely light weight, and not attached to the walls very well.
I took the A/C off my roof, but that was also due to a ridiculous installation that involved putting a 4' x 4' piece of plywood on the roof with no sealant below.
Definitely ladder work IMHO.
Randy
OR335d is offline   Reply With Quote
Old 08-28-2020, 06:26 AM   #3
Minnesota
Makes sense, thanks Randy.
I was able to take the AC cover off, no blockage of drain holes. A few old wasps nests. I suspect that gasket needs replacing and the fact the Fiber Stream was not totally level. It is difficult to level the rear corner with the drains. I need to figure out a better way to level that corner. The original jack stand is not cutting it.
fiber stream
Another Fiber Stream Arrives John Lawrence Modifications, Alterations and Updates 10 12-31-2005 06:43 PM
Re-post: My Fiber Stream Story Frederick L. Simson Modifications, Alterations and Updates 25 12-27-2005 09:04 PM
Fiber Stream Interior Legacy Posts General Chat 2 08-11-2003 03:19 PM
Fiber Stream Trailer Legacy Posts General Chat 7 08-06-2003 07:40 AM
Fiber Stream Buyer General Chat 0 01-01-1970 12:00 AM
