Gaskets for Trillium 1300 1975 - Fiberglass RV
Old 07-25-2020, 06:22 PM   #1
Trailer: Trillium 1300
QC
Hello all!
I am about to remove the windows on my Trillium 1300, 1975. Everything there seems original so of course the windows gaskets are dry and need to be replaced. I would like some advice from someone who did the same so I can order the right parts. If you have parts numbers and length needed for all the windows it would be awesome. Is there anything else apart from the gaskets that would need to be changed (I already have the butyl tape, the stainless steel screws and I will change the wood frames too.) thanks!
I added some pictures of the visible gaskets, there might be others when I disasemble the windows
Alexandre is offline   Reply With Quote
Old 07-26-2020, 10:07 AM   #2
JR MASTER's Avatar
Trailer: TRILLIUM
Trillium window gaskets
Hi,
We have recently acquired a 1980 Trillium 1300 and have removed all windows.Replaced wood trim,seal tape and screws ,and reinstalled.
We haven't replaced rubber trim yet but,found some items for Hehr 4900 jalouise widows at vintagetrailergaskets.com
Joe ( Cool Dude) @ Outbacktrailers ( Calgary Canada)) has also been very helpful sending us a window frame ,operator and other misc. parts.
Hope this helps. Good luck.
JR
Folks on this forum are so cool to help each other and we sure appreciate it!Click image for larger version
JR Master
JR MASTER is offline   Reply With Quote
Old 07-26-2020, 11:53 AM   #3
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Alexandre,
For the top seal, the Hehr part number is 009-097.
For the Y seal (install on the sides and bottom), the Hehr part number is 009-289.
For the screw cover in black, the Hehr part number is 011-363.
We have purchased and installed all three of these products on our Trillium 4500.
Old 03-18-2022, 05:39 PM   #4
Trailer: Trillium
John in Michigan ?
Hi! Re the Hajer black mouldings for the windows. Do u know if the part #'s you listed would also work for a 1973 Trillium 1300? Are those parts available on Amazon.ca? Thanks.
JuliusB is offline   Reply With Quote
Old 04-14-2022, 10:48 AM   #5
judi z's Avatar
Trailer: 76 Trillium
Originally Posted by John in Michigan View Post
Alexandre,
When you replaced the gaskets, did it make a difference in how the windows seal? Do the windows need to be removed to replace? Where did you order these parts - vintage trailer's part #'s do not match? About to paint my Trillium and am thinking of dealing with this stuff too.
Cheers,
Judi
judi z is offline   Reply With Quote
Old 04-14-2022, 11:21 AM   #6
Replacing the top seal and y seal will help reduce drafts, but far from eliminating drafts.
These windows are designed to shed water effectively even without seals.
Don't clearly remember, but I believe the window frame must be disassembled to replace the y seals. Also had difficultly removing the top seal (it had solidified) and found it easier to remove once the frame was disassembled.
Old 04-14-2022, 11:27 AM   #7
Also, I was able to reduce emergency exit window draftiness by adjusting (tightening) the two spring loaded window latches.
trillium
For Sale: 1975 trillium 1300 1300 Micey NEW Fiberglass RV Classifieds | Buy, Sell, Trade 0 06-26-2019 06:16 PM
Trillium 1300 Jalousie Window Gaskets Kommander Care and Feeding of Molded Fiberglass Trailers 15 05-08-2018 05:28 AM
Windows and gaskets that leak MyronL Problem Solving | Owners Helping Owners 4 10-27-2006 05:56 PM
Rubber gaskets for Scamp Windows for sale jaye580 Classified Archives 0 08-13-2006 10:25 PM
Front or rear window gaskets JOE DRISSEL Problem Solving | Owners Helping Owners 0 04-25-2006 07:13 PM
