Trillium - original axle? - Fiberglass RV
Old 03-23-2021, 12:08 PM   #1
Trailer: Trillium 1300
Hi folks, new to this forum and new to a 1975 Trillium 1300. Thanks for the wealth of knowledge on here, helped me out aligning the door and making a plan for the frame work - looks in good shape but the recall reinforcements haven't been done on it. Going to lift off the shell and give it a proper undercoating while at it.
Question: Is there any sure way to tell if the axle is original? I looked through the posts on assessing your axle and it feels fine, lot's of clearance and moves well when trailer raised or bounced, and rides slightly lower on the trailer's heavy side. I'm planning on installing electric brakes, so trying to decide if necessary to replace the axle too. The axle has the square 4 hole plates for brakes, and though welded to frame does have bolt slots too - not sure if that is a sign is was installed later? Any insights appreciated. Thanks!
Jonathan K is offline   Reply With Quote
Old 03-23-2021, 06:08 PM   #2
David Tilston's Avatar
My orignal axle had a data plate in the middle of the cross member. It was also a 2000# axle. If yous has been replaced. It was likely replaced with a higher capacity axle.
Old 03-23-2021, 06:46 PM   #3
My original 1977 axle has both bolt slots and brake backing plates and still has good clearance.
Old 03-24-2021, 03:00 PM   #4
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Hello,
My 1978 Trillium still has the original axle that has both the little ID plate
on it and slots in the mounting brackets.
Sure needs a new axle... Big job!
Uncle Larry
Larry C Hanson is offline   Reply With Quote
Old 03-25-2021, 08:14 AM   #5
Yep, it's original. Pulled the frame out and the plate reads Ingersoll 1500lb E4. As mentioned, suspension still appears good, however I do want to add brakes so I guess now is the time to swap it. Dexter #9 I take it is the usual replacement, can anyone point me towards a Canadian supplier?
Frame looks in overall good shape, the front bolt hole fish plating hasn't been done so will definitely do that and add mounting flanges for the shell, and paint it, any other recommendations while I have it out?
Old 03-25-2021, 08:38 AM   #6
Princess Auto is having a sale on 3500# brakes. Now I have never mixed large brakes with a smaller axle, so you should confirm that the bolt holes will line up, and the brakes will fit inside your rims.
https://www.princessauto.com/en/elec...?skuId=8212086
These are only half of the assembly, you will also need the hubs that fit these brakes. This is where I am really out on a limb. The stub axle on a 1500# axle will likely be smaller and not fit a 3500# hub.
https://www.princessauto.com/en/3500...t/PA0008211716
I am hoping other, more knowledgeable folks, will chime in.
Old 03-25-2021, 09:55 AM   #7
I am a big fan of the Flexi-ride axle. The main benefit is the angle of the torsion arms are adjustable. So you can get more ground clearance relatively easily.
Now that the frame is out, I would add eight fish plates, two each at each bend. You will see how the frame tubing is collapsed at each bend. I would also add plates where the rear frame overlaps the front frame. Some members have had that connection fail. Super easy to do while the frame is out.
Old 03-26-2021, 12:41 PM   #8
Thanks for the tips Bill. Contacted Canadian Axle that makes the Flexiride, I do like the sound of the adjustable arms and their pricing seems to be better than Dexter axles here in Canada. Have you put a Flexiride on a Trillium? Just making sure the dimensions all line up.
Old 03-26-2021, 02:07 PM   #9
It’s on my do list right now. I know others have used the flexiride on Trilliums. One thing on flexiride the arms are shorter than Dexters. Installer just needs to attach it so the arm puts the wheel in the center of the wheel well. Measure twice, weld once!!
Old 04-08-2021, 09:58 AM   #10
Trailer: 1973 Trillium 1300
Where are you located Jonathan? I’ve been looking this spring to do the same thing (frame fish plates and new axle) on our ‘73 1300 here in BC. Got a quote for a dexter (was around $600-800, takes 6 weeks to arrive). What was your flexiride quote?
Alex T is offline   Reply With Quote
Old 04-08-2021, 11:25 AM   #11
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
I just got a quote for a 2000# Flexiride with brakes 5 on 4.5-Inch from Canadian Axle for CAN$530 for my Scamp 13-foot.
They have all the parts, and think they can ship it 1 week from my payment. (Maybe FRIDAY!)
Michaela was wonderful answering all my questions over about two weeks as I measured and figured out what I needed.
Michaela Craig
Canadian Axle Inc.
Sales Coordinator
613-653-7839
michaela@canadianaxle.com
AlanKilian is offline   Reply With Quote
Old 04-08-2021, 01:33 PM   #12
That is about $410 US. Very nice!
Old 04-08-2021, 01:38 PM   #13
Massachusetts
Indeed.
It cost me US$600 including shipping to Cambridge, MA (And since my credit card doesn't have a foreign transaction fee, that's all it cost.)
The replacement axle from Scamp is US$500 without shipping (and is out of stock with no estimate on when they'll get more in), so I think this is an excellent deal.
Old 04-09-2021, 08:18 AM   #14
Hi Alex, $490 for the flexiride axle with 7" brakes, and $200 to ship it to Smithers BC (and just 5% GST as ships from ON) Canadian Axle are great to deal with and shipped in a few days, should be here this weekend. Good luck!
Old 01-19-2022, 11:07 AM   #15
Trailer: Trillium
WA
Jonathan or others, when you add mounting flanges to the frame doesn't that move the location of the holes where bolts will come through the shell? Probably no big deal as I have lots of fiberglass patching ahead of me, but just want to be sure I understand. Do you locate the flanges right next to the original mounting holes? Thanks! I need to do much of the same frame work you do... and the axle.
esgarbanzo is offline   Reply With Quote
Old 04-26-2022, 06:24 AM   #16
Trailer: Trillium
ON
starting angles
would anyone be able t upload their order form? im looking at getting a flexiride and im not sure what the starting angle should be? thanks
CaptainSnkyRik is offline   Reply With Quote
Old 04-26-2022, 07:05 AM   #17
Massachusetts
The nice thing about Flexiride is you don't have to get the angle right the first time.
Here's my 1977 Scamp 13' with a 4" square box between the bottom of the frame and the top of the axle mount.
12-degrees down.
It's pretty high and I've thought about moving closer to zero, but it's fine.
We use a small step stool outside the door so we can get in and out easily.
Old 04-26-2022, 07:07 AM   #18
Trailer: Trillium
ON
thank you. this really helps
Old 04-26-2022, 07:12 AM   #19
Massachusetts
I did notice that the buildsheet says 4 on 4.5, but I've got 5 on 4.5 bolt pattern.
axle, trillium
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
