Replace Shower Faucets/Diverter in Parkliner - Fiberglass RV
Old 06-24-2021, 12:28 PM   #1
Trailer: ParkLiner
Virginia
Never mind. I forgot the closet is right behind the shower. I have access to everything I need to take the assembly apart or replace it.
Old 10-07-2021, 08:41 AM   #2
Trailer: ford
mexico
The steps to Replace an RV Shower Faucet. The first thing you must do is turn off the motorhome’s main water supply. Dump the water from the RV shower system by opening all the taps – both the hot and cold water. Then, remove your old shower faucet and disconnect the shower water lines. Check the two water pipes running from the shower and through the wall. These fixtures often have a fastener that secures them in their place. Loosen the hardware using a wrench and disconnect the hot and cold water lines. Finally, install the new shower faucet. Get your new shower faucet and check the location of the hot and cold water connections. Grab the loose water pipes and connect them to their respective taps using a wrench. You might want to apply Teflon tape over the threads to create a watertight seal.
Natalie21 is offline   Reply With Quote
Old 10-09-2021, 06:58 AM   #3
Trailer: ford
mexico
Turn on your shower’s water supply and open the shower faucet. Make sure there are no leaks. If you see the RV shower faucet leaking, you might want to check the connections.
parkliner
Sources for sinks, faucets, folding shelves macbethdt Modifications, Alterations and Updates 18 12-24-2020 01:56 PM
To replace or not to replace rivets? brettrae Care and Feeding of Molded Fiberglass Trailers 7 10-03-2019 02:59 PM
How to access under the faucets? Gilles Problem Solving | Owners Helping Owners 8 06-05-2016 09:28 AM
faucets for kitchen and bath kevin61 Problem Solving | Owners Helping Owners 5 08-22-2011 06:52 PM
To Replace Or To Not Replace??? Susan Landis Modifications, Alterations and Updates 11 07-29-2011 09:19 AM
