Hi! We own a 1973
Trillium 1300 trailer that is currently getting the body and
paint done on it but I want to focus on the interior now. I have seen great posts re how to primer/paint the ensolite so will follow those. My question is what are people
painting the floor and fibreglass supports around the closet and entire sink/cupboard area with? Sanding first w 80 grit and then prime/paint? Has anyone painted the inside of the cubby hole compartments under the front gaucho and the rear? If yes, with what? Prep? If not, is it because the fibreglasss needs to breathe vs completing sealing it up? I am just trying to make it cleaner for storage of things.
Our trailer did not have a
furnace as the PO removed it. A replacement cannot go where it was originally as that space now has 2 cupboard doors for storage. I thought I saw a pic where someone installed it in the base of the cubby where the water tank usually goes? Is this possible and if yes, can I still use the original exterior vent grille with ? hose/tubing from the back of the
furnace to the grille vent? Any recommendations of furnaces would also be appreciated.....I think the original was a Suburban model.
Thanks and have a wonderful day!
