1971 Trillium 1300 Axle Replacement - Fiberglass RV
Old 04-26-2022, 05:04 AM   #1
Trailer: Trillium
ON
Question 1971 Trillium 1300 Axle Replacement
Hello All,
I recently discovered my 1971 trillium 1300 needs a new axle. I was replacing my tires and noticed my torsion axel did not budge when lifting the trailer which makes me believe that it needs a replacement. I'm not sure about the torsion axle dimensions and information for replacement (If anyone knows the size and where to get one that would be great, I am in Ontario, Canada) but I'm also seeing some folks who switched to leaf spring axle. I'm curious if anyone has switched/replaced their axel and what their experiences were doing it and if there is any recommendations you may have for me. Im interested in flexiride aswell. does anyone know what the starting angle should be?
Thanks for your time
CaptainSnkyRik is offline   Reply With Quote
Old 04-26-2022, 06:11 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Here's where I had my Trillium 4500 axle replaced:
Paul Neumeister
A1 Auto Refinishing
345 Huron Rd
Sebringville, ON N0K 1X0
+1 519-393-6410
Paul first welded on an adapter plate, then bolted on the new axle. (original axle was welded on)
I was very happy with the result. He had previously replaced the axle on my Boler 13.
Paul also does general repairs and body work on molded fiberglass trailers and sells some new old stock trailer parts.
Old 04-26-2022, 10:22 AM   #3
steve67's Avatar
Trailer: '79 Boler
on Ontario
Paul replaced the axle in my '79 Boler just a couple of weeks ago. Really a straight guy. Recommended.
steve67 is offline   Reply With Quote
Old 04-27-2022, 06:25 AM   #4
Trailer: Trillium
ON
would you happen to have a photo of the welded plate? mine is currently welded to the frame and i see that if i want to bolt on, ill have to lift the trailer body off.
Old 04-27-2022, 07:16 AM   #5
Nathan,
Paul was able to replace the axle without separating the body from the frame. My Trillium 4500 axle replacement is explained in this thread:
https://www.fiberglassrv.com/forums/...xle-79244.html
Read the whole thread. In short, here was the challenge:
"This is not a simple repair. It is challenging because the original axle is welded into a joint where two frame rail sections are welded together. The axle bracket actually reinforces the frame rail joint. Because the new axle will be bolted in instead of welded, the frame rail joints will need to be reinforced in some other way."
Paul reinforced "the frame rail joints that intersect w/the axle brackets by adding laser cut fish plates to these joints." These are sturdy, long plates that span the frame rail joints.
Old 04-27-2022, 08:37 AM   #6
David Tilston's Avatar
Originally Posted by John in Michigan View Post
Nathan,
I need pictures please.
Old 04-27-2022, 09:16 AM   #7
I know I have pics. Will see if I can find them. Sold the trailer a year ago...
Old 04-30-2022, 11:40 AM   #8
Just had axle replaced on my1980 trillium 4500. It was clapped out with torsion bars tilted downward, and hitting hard on the smallest bumps. It was not a simple or cheap job. Don’t have details with me but can provide if interested. Each trailer needs to be measured accurately for width and axles made to order. Torsion arms are level now,height of trailer is increased about 2 inches and rides so much smoother.
Thomas W is offline   Reply With Quote
Old 04-30-2022, 03:56 PM   #9
Trailer: Aliner
Dexter axle
I live in Calgary. I went to a local shop called Standen's and ordered a Dexter axle. Although the old axle was rated at 2,000-lb, they were able to beef the replacement up to 2,200-lb. (Didn't want to go all the way up to 3,500-lb.) Did the installation myself. Unbolted the old axle and brought it in to the shop, so they could use it as a template for the fittings. The new one fit like a charm. Kept the old hubs and brakes and just bolted them onto the new axle. Took it down to Utah about four weeks ago, and had no problems whatsoever.
CalgaryEscape is offline   Reply With Quote
Old 06-06-2023, 04:04 AM   #10
Trailer: Trillium
Thomas- can you tell me where you had your axle replaced? I have a 1979 Triullium 4500 that probably needs a new one. I'm in Ontario (for now).
Vic Berger is offline   Reply With Quote
Old 06-06-2023, 04:09 AM   #11
steve67's Avatar
Trailer: '79 Boler
on Ontario
Paul Neumeister - Fibreglass RV Parts, Repairs, and Service by Paul Neumeister
345 Huron Road, Sebringville, Ontario, NOK 1X0
Phone: 519-393-6410 (shop) 393-6776 (home)
Old 07-03-2023, 01:49 PM   #12
Trailer: Trillium 1300 '78
BC
Canadian Axle Inc in Invernary ON
We just took delivery of a FlexRide for our 1300 from Canadian Axle Inc in Invernary ON. The person who assisted us Michaela) was awesome to work with. It was ~$800 plus delivery, which was very reasonable to our remote island in BC and came to around $1100 all told. This all happened between May and June 2023. We're getting ready to stick it on as we speak. We opted for the electric brake option, just in case, but maybe that wasn't necessary for such a light trailer. Might be handy if we end up getting a smaller vehicle to tow it around.
Crash420 is offline   Reply With Quote
Old 07-03-2023, 02:37 PM   #13
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
She helped me get an axle for my 1977 Scamp 13' a couple of years ago and was awesome then also.
AlanKilian is offline   Reply With Quote
axle, trillium
Need New Window - 1971 Boler 1971 13 FT varible154 Hi, I am.... 0 01-15-2021 09:16 PM
GA - 1971? - Trillium 1300 - Front quarter bathroom David Tilston Referrals: Molded Fiberglass Trailers 27 12-07-2020 08:37 AM
1971 Trillium 1300 gets a new haircut coalminecanary Modifications, Alterations and Updates 7 10-10-2013 07:31 AM
How do I remove the body from the frame? 1971 Trillium 1300 coalminecanary Modifications, Alterations and Updates 26 06-11-2012 09:41 AM
Just bought a 1971 Trillium 1300 in dire need of TLC coalminecanary Hi, I am.... 16 10-31-2011 07:17 AM
