Trillium 4500 rear window - Fiberglass RV
Old 05-05-2022, 09:19 PM   #1
sliwka's Avatar
Trailer: L’air Trillium 1300 on order
Can anyone show me picture of rear big window mechanism?
I can open mine, but something is missing and it cannot be held open.
sliwka is offline   Reply With Quote
Old 05-06-2022, 08:00 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
On the Trillium 4500 the rear window is usually split between an emergency exit window on one side (opens in emergency but doesn't have a mechanism for holding it open) and a 3-pane jalousie window. If the 3-pane jalousie window doesn't "stay open" usually that's because the torque operator box is worn out and needs to be replaced.
Old 05-06-2022, 08:03 AM   #3
sliwka's Avatar
In that case my emergency window cannot stay open
Old 05-06-2022, 08:10 AM   #4
David Tilston's Avatar
Like every other 4500. The window you are talking about has no screen either. that is because it is an emergancy escape window. If you prop it open, the bugs will get in.
Old 05-06-2022, 08:14 AM   #5
The emergency exit window on my Trillium 4500 (before I sold the trailer) did not have a way to be propped open. That appeared to be "by design". You could design a mechanism for holding the window open.
trillium
replacement window glazing for rear window on 1975 scamp Josh Wink Problem Solving | Owners Helping Owners 6 07-15-2016 04:05 AM
1979 Trillium 4500 Rear Escape Window seals CampingBlairs Care and Feeding of Molded Fiberglass Trailers 0 07-01-2015 09:55 AM
window gravel guard on rear window too?? summer scamp Modifications, Alterations and Updates 6 04-05-2015 06:50 PM
Trillium 4500 Rear Window Large Pane Replacement spotcatbug Problem Solving | Owners Helping Owners 2 12-02-2011 03:19 PM
rear window removal Trill 4500 ryan a Problem Solving | Owners Helping Owners 3 10-09-2008 10:02 AM
